Thread Closed
Kinetic Energy among a set of Point Charges
Share Thread Thread Tools
Feb15-10, 02:59 PM   #1
A set of point charges is held in place at the vertices of an
equilateral triangle of side 10.0 cm, as shown in the figure (a) .
Find the maximum amount of total kinetic energy that will be
produced when the charges are released from rest in the
frictionless void of outer space.
2. Relevant equations
Unsure, but believe this one is paramount:
V = k*(q/r)
3. The attempt at a solution
I'm using the formula V = k(q1)/r1 and the example in my textbook on page 590,
which is for only 2 point charges within an isosceles triangle, simply adds the
V1 + V2 to get Vtotal, so I assumed (probably incorrectly) that I could use
this method with 3 charges within an equilateral triangle and simply added the
V1 + V2 + V3 = 809.1 N*m/C. However, they want the answer in joules,
so what if I was even correct in my method, what should be done to my
answer in order to convert it to joules? Are N*m/C = Volts? Wouldn't that
mean I would need to then multiply by the same charges I just multiplied by?
And would I use each individual charge added together, or... what do I do with
these Coulombs?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Thread Closed
Tags
coulombs, electricpotential, joules, newtonmetwers, volts
Thread Tools
Similar Threads for: Kinetic Energy among a set of Point Charges
Thread Forum Replies
Conservation of energy in EM with point charges Classical Physics 6
potential energy of point charges Classical Physics 4
Kinetic Energy/Circular Motion and figuring out point charges Introductory Physics Homework 5
kinetic/potential energy of charges as they approach each other Introductory Physics Homework 2
Kinetic Energy of Point Charges Introductory Physics Homework 1
