Maximum Height and Range of a Projectile at a 60-Degree Angle
  • Thread starter Thread starter azsx1
    Projectile
The discussion revolves around a projectile motion problem involving a cannon that shoots a projectile at a 60-degree angle with an initial speed of 30 m/s. Participants are tasked with calculating the maximum height and range of the projectile.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to calculate the maximum height using a formula involving initial speed and angle but expresses uncertainty about the correctness of their result. Other participants suggest that there may be an error in the calculation. There are attempts to use different formulas, including one involving distance, time, and acceleration, leading to confusion about the appropriate approach for finding the range.
Participants are actively engaging with the problem, with some providing guidance on the calculations while others are exploring different methods. There is a recognition of the need to clarify assumptions and the correct application of formulas, but no consensus has been reached on the correct approach for calculating the range.
Participants are navigating the constraints of the problem, including the need to derive time and distance without having all variables defined. There is an acknowledgment of the limitations of certain formulas when specific values are unknown.
azsx1
a cannon shoots a projectile @ ANGLE OF 60 DEGREES ABOVE HORIZONTAL W INITIAL SPEED OF 30M/S. CALCULATE MAX HT OF PROJECTILE AND ITS RANGE.
U^2Sin^2O
30^2sin^260/9.8 = 67.5m not sure if this is correct!
U^2Sin^2O
Welcome to PF!
Hi azsx1! Welcome to PF! :smile:
(have a theta: θ and try using the X2 tag just above the Reply box :wink:)
U^2Sin^2O
Yes (for the maximum height), except you're a factor of 2 out. :wink:
Thank you! I think I am overthinking this, but I tried doing another way with d=v0t + .5at^2 formula. Thought for sure this would work! so i did and got a different answer! ugh. Can you help with range?
Well, that'd never work, since you don't know d or t. :redface:
That's why you had to use a formula without t. :smile:
Yes … but you have to try it first.
okay, i got t by imputting the initial velocity of the x/y components/ a for gravity. wouldn't this work? Also the range, i just plugged the numbers in formula d=v0t+.5at^2.
Not following you. :confused:
Can you put the numbers in?​
The time it takes the projectile to reach it's peak is calculated by:
[tex]t = \frac{v_{iy}}{g}[/tex]
where [itex]v_{iy}[/tex] is the initial vertical velocity (the y-component) and [itex]g[/tex] is the acceleration of gravity (9.8 m/s/s)[/itex][/itex]
28K
