Why Is Tension Calculated Using the Smaller Mass in a Two-Block System?
  • Thread starter Thread starter mybrohshi5
    Explain Tension
The discussion revolves around a physics problem involving two blocks connected by a string being pulled by a force on a frictionless surface. The original poster seeks to understand why the tension in the string is calculated using the smaller mass rather than the larger mass or the total mass of the system.
  • The original poster calculates the acceleration of the system and the tension in the string but questions the reasoning behind using the smaller mass for the tension calculation. Participants suggest considering free body diagrams and the net forces acting on the blocks.
Participants are exploring the reasoning behind the tension calculation, with some providing insights into free body diagrams and Newton's laws. The discussion is productive, with participants clarifying concepts and reinforcing understanding without reaching a definitive conclusion.
The original poster is preparing for an upcoming physics exam and is focused on grasping the underlying principles of tension in a two-block system.
mybrohshi5
Two blocks connected by a string are pulled across a horizontal frictionless surface by a horizontal force of magnitude F=14.0 N. What is the tension (T) in the connecting string?
so you have block 1 (mass of 2kg) then the string then block 2 (mass of 5kg) then the force pulling it of 14 N
[1]---T---[2]---->F
f=ma
t=ma
so i found the acceleration:
a = f/m
a = 14/(5+2) = 2 m/s2
then i found the tension:
t = ma
t = 2kg(2m/s2)
t = 4 NWhat i am wondering is why do you multiply the 2kg block by the acceleration to get the tension and not multiply the 5kg block or the total of 7kg by the acceleration to get the tension?
can anyone explain please? i have a physics exam tomorrow and i am studying and really trying to understand tension :)
thank you
[1]---T---[2]---->F
f=ma
t=ma
a = f/m
t = ma
t = 2kg(2m/s2)
t = 4 N
thank you
You should study free body diagrams (FBD's) first. You solved for the acceleration by looking at the system of both blocks. Good. The only net force acting on the system of 2 blocks is the 14 N force. The tension in the cord between the 2 blocks is internal to the system, and does not enter into the equation when looking at the system of 2 blocks together. Now you then solved for T by isolating the first block in a FBD, using Newton 2. You solved T =4 N, where T is the only force acting in the x direction. Now you could have drawn a FBD of the 2nd block, but then, the NET force acting on the 2nd block alone would be 14-T = ma = (5)(2) =10; then solve T = 4 N. Same result. OK??
yes that makes sense :) thank you
almost all questions are good ones, but yours was an excellent one. One of the keys to mastering physics is to master free body diagrams , Newton's laws, and :rolleyes:the plus and minus sign.
yeah i have been figuring that out lol ;) thanks again for all the help i have got from you. i really appreciate it and hopefully it helps me on my exam tomorrow!
  • · Replies 52 ·
