Debugging C Code: Unexpected Output
  • Thread starter Thread starter Quincy
    Output
The discussion revolves around debugging a C code snippet that produces unexpected output when calculating values based on user input for left and right endpoints. Participants explore issues related to input handling, potential infinite loops, and the correct usage of format specifiers in the C programming language.
  • Debugging
  • One participant reports unexpected output when inputting values for left and right endpoints, specifically mentioning the output format as "1.910014e-3074.243992e-314".
  • Another participant suggests changing the format specifiers in the scanf function from %f to %lf to correctly read double values.
  • A participant acknowledges fixing the initial problem but encounters a new issue where the output does not display, suspecting an infinite loop.
  • Another participant expresses doubt about the absence of an infinite loop and suggests posting the code directly in the forum for better clarity.
  • One participant identifies a problem in the while loop of the trpzd_method function, indicating it may be the reason for the function not returning as expected.
  • A participant humorously reflects on discovering the issue, noting that it was a mistake discussed in class by their professor.
Participants do not reach a consensus on the cause of the output issues, as some suspect an infinite loop while others focus on format specifier corrections. The discussion remains unresolved regarding the final output behavior of the code.
There are limitations in the provided code, such as the potential for an infinite loop and the incorrect handling of increment calculations within the trpzd_method function. These aspects are not fully resolved in the discussion.
Quincy
http://pastebin.com/d49e23fad --
I input 0.0 for the left endpoint and 100.0 for the right endpoint, yet it printed "1.910014e-3074.243992e-314"... What is going on??
Code:
int main()
	int sub_intrvl;
	double left_ep;
	double right_ep;
	double answer;
	printf("Number of Subintervals: ");
	scanf("%d", & sub_intrvl);
	printf("Left endpoint: ");
	scanf("%f", & left_ep);
	printf("Right endpoint: ");
	scanf("%f", & right_ep);
	printf("%e", right_ep);
	printf("%e", left_ep);
I would change the %f conversion specifiers in scanf() to %lf, since you're reading in a double value.
Mark44 said:
Code:
int main()
	int sub_intrvl;
	double left_ep;
	double right_ep;
	double answer;
Thanks, I got that problem fixed. But now, when i input everything, the output doesn't display for some reason. I thought I had an infinite loop, but that doesn't seem to be an issue. http://pastebin.com/m32ac3107
I think you might have an infinite loop, despite what you are saying.
BTW, why not post your code here? Just put it between a [ code] tag and the beginning and a [ /code] tag at the end -- without the leading spaces.
Code:
#include <stdlib.h>
#include <stdio.h>
#include <math.h>
double trpzd_method(int, double, double);
double f(double);
int main()
	int sub_intrvl;
	double left_ep;
	double right_ep;
	double answer;
	scanf("%lf", & left_ep);
	scanf("%lf", & right_ep);
	answer = trpzd_method(sub_intrvl, left_ep, right_ep);
	printf("%lf", answer);
	system("PAUSE");
double trpzd_method(int sub_intrvl, double left_ep, double right_ep)
	double total = 0.0;
	double final_result;
	double first_value = f(left_ep);
	double last_value = f(right_ep);
	double increment = (right_ep - left_ep)/sub_intrvl;
	while((left_ep + increment) <= right_ep);
		total += f(right_ep + increment);
		increment = (increment + ((right_ep - left_ep)/sub_intrvl));
	final_result = increment*((0.5*(first_value + last_value)) + total);
	return final_result;
double f(double x)
	double e = 2.71828182845904523536;
	double exponent = (-1)*(x)*(x);
	double result = pow(e, exponent);
	return result;
From your description, trpzd_method() isn't returning, and I can see exactly why. Take a very close look at your while loop.
Thanks, I found the problem. The funny thing is, the professor was just going over that today, and I was thinking "lol who would make that mistake?".
  • · Replies 23 ·
