How Does a Bowling Ball's Speed Change Down an Incline?
The discussion focuses on calculating the translational speed of a 30kg bowling ball, modeled as a uniform solid sphere, rolling down a 1.5m incline under the influence of gravity (9.81 m/s²). The conservation of energy principle is applied, where potential energy (mgh) is converted into kinetic energy, represented as the sum of translational and rotational kinetic energy. The correct formula used is mgh = 1/2 Iω² + 1/2 mv², leading to the conclusion that translational speed is derived from the relationship between linear and angular velocities.
  • Understanding of conservation of energy principles in physics
  • Familiarity with rotational dynamics and moment of inertia (I = 2/5mr²)
  • Knowledge of translational versus rotational speed concepts
  • Basic algebra for manipulating equations
  • Study the conservation of energy in mechanical systems
  • Learn about the moment of inertia for different shapes
  • Explore the relationship between linear and angular velocity
  • Investigate real-world applications of rolling motion in physics
Students and educators in physics, mechanical engineers, and anyone interested in the dynamics of rolling objects and energy conservation principles.
BoldKnight399
A 30kg bowling ball with a radius of 11 cm starts from rest at the top of an incline 1.5m in height. Find the translational speed of the bowling ball after it has rolled to the bottom of the incline. (assume that the ball is a uniform solid sphere) acceleration of gravity is 9.81m/s^2. Answer in units of m/s. (I=2/5mr^2)
so I was thinking of treating this as a simple conservation of energy question, just substituting I and w for kinetic energy.
mgh=1/2Iw^2
mgh=1/2(2/5mr^2)(v/r)^2
so:
mgh=2/10mrv^2
I think that this works, but to be honest, I don't understand what translational speed is.
Hi BoldKnight399! :smile:
(have an omega: ω and try using the X2 tag just above the Reply box :wink:)
BoldKnight399 said:
… I was thinking of treating this as a simple conservation of energy question, just substituting I and w for kinetic energy.
mgh=1/2Iw^2
No, KE of a rotating object is rotational KE plus ordinary KE (ie as if all the mass was moving with the velocity of the centre of mass) …
1/2 Iω2 + 1/2 mv2 :wink:
(And translational speed or velocity is simply the speed or velocity of the centre of mass)
  • · Replies 21 ·
  • · Replies 32 ·
