| Thread Closed |
Two Charged Capacitors in Parallel |
Share Thread | Thread Tools |
| Feb16-10, 08:57 PM | #1 |
Two large area parallel plate capacitors, labeled P and N, are connected as shown in the figure below. The charge on each plate is indicated in the figure, in μC. I. The capacity of N (on the right) is 27.5 μF. Calculate the capacity of P. 1.34×10-5 F (Correct) The plate separation of capacitor of N (on the right) is doubled. Calculate the new value of the charge on P. 2. Relevant equations q=CV total initial charge=total final charge C=[tex]\epsilon[/tex]A/d 3. The attempt at a solution [tex]C_{Ni}[/tex]=[tex]C_{Nf}[/tex]/2 because the distance has doubled (C=[tex]\epsilon[/tex]A/d) [tex]q_{Ni}[/tex]+[tex]q_{Pi}[/tex] = [tex]q_{Nf}[/tex]+[tex]q_{Pf}[/tex] [tex]q_{Ni}[/tex]+[tex]q_{Pi}[/tex] = [tex]C_{Nf}[/tex]V+[tex]q_{Pf}[/tex] [tex]q_{Ni}[/tex]+[tex]q_{Pi}[/tex] = [tex]q_{Pf}[/tex]*[tex]C_{Nf}[/tex]/([tex]2*C_{Pf}[/tex])+[tex]q_{Pf}[/tex] using q=CV because the voltage drop will be the same between the two final capacitors then I solved for qPf |
| Thread Closed |
| Tags |
| capacitor, charge, parallel, voltage |
| Thread Tools | |
Similar Threads for: Two Charged Capacitors in Parallel
| Something about parallel capacitors | Classical Physics | 8 | ||
| Parallel capacitors | Electrical Engineering | 2 | ||
| Parallel capacitors | Introductory Physics Homework | 7 | ||
| 2 Capacitors in Parallel | Introductory Physics Homework | 4 | ||
| Capacitors in series and parallel | Introductory Physics Homework | 6 | ||
