What is the role of the Higgs boson in giving mass to particles?
The discussion revolves around the role of the Higgs boson in providing mass to particles, exploring its theoretical implications, the nature of the Higgs field, and the relationship between the Higgs boson and other fundamental particles. Participants express confusion about the Higgs boson's composition and its function within the Standard Model of particle physics.
  • Some participants express confusion about the nature of the Higgs boson and whether it is composed of other particles, particularly in relation to quarks.
  • One participant states that the Higgs boson is a fundamental particle and not made of anything else.
  • Another participant explains that the Higgs boson has couplings to quarks and leptons, suggesting it gives mass to particles it interacts with, but acknowledges the complexity of the interactions.
  • A participant argues that it is misleading to say the Higgs boson "gives" mass, proposing instead that the Higgs field is responsible for mass, with the Higgs boson being a necessary component for theoretical consistency.
  • There is mention of the Standard Model's reliance on the Higgs boson for explaining the mass of particles, with implications for the validity of the model depending on the Higgs boson's existence.
  • Some participants reference alternative views on the Higgs boson, including skepticism about its significance in theoretical physics and the possibility of other mechanisms for mass generation.
  • A later post introduces the idea of a top quark condensate as a potential alternative to the Higgs mechanism, suggesting a different approach to mass generation without an elementary scalar boson.
Participants do not reach a consensus on the role of the Higgs boson and the Higgs field. There are multiple competing views regarding the nature of mass generation and the significance of the Higgs boson within the Standard Model.
Participants express varying levels of understanding of quantum mechanics and the Standard Model, which may affect their interpretations of the Higgs boson's role. There are unresolved questions about the implications of the Higgs boson's existence for the validity of the Standard Model.
clm321
i know no one has ever seen them before there just a theory but my question is what are they? do they make up quarks to give everything mass or what I am kinds confused.
wikipedia and google
i tryed to wiki it it didnt answer my question of what there made of and stuff i want to know what they go into. don't they go into quarks and that's what gives them mass or what?
The Higgs boson is just another particle that may or may not exist. It has couplings to the quarks, leptons (possibly neutrinos, but we don't know for sure) and the W and Z gauge bosons. To everything that it touches, it gives mass. I would suggest looking up "Higgs Mechanism" to get an understanding of that, both here and on the web. I don't know how much quantum mechanics you know, so I can't be more specific than that.
It also touches massless things, but indirectly. For example: a Higgs boson can decay to two photons. What it REALLY does is that it decays to a quark-antiquark pair (for example), and the quarks annihilate into two photons, but this happens so quickly that we only see it as a higgs ---> 2 photon event. In fact, if the Higgs exists and has the mass many people think it has, this is the best chance we have of seeing it (detectors at the LHC are set to look for two photons!).
That's obviously a bit oversimplistic, but I hope it helps getting you started!
To answer your other question, the Higgs boson isn't made of anything. It's a fundamental particle (in the simplest setups.)
A while ago I wrote a post that tried to provide a simplified version of the math behind the Higgs field. I'm not sure if it would be of any use to you, but if you want to read it:
https://www.physicsforums.com/showthread.php?t=368566
Personally, I think it's a little misleading to say that the Higgs boson "gives" other particles mass. Particle physicists say that because, way back in the old days, we had a theory called the Standard Model that very elegantly described all the known particles and forces (except gravity), with just one problem: the theory predicted that none of these particles would have any mass. Peter Higgs was the one (well, not the only one, but apparently the most famous one) who figured out how to modify the theory so that its particles could have mass, and the way he did so was by introducing a new particle, which is what we now call the Higgs boson. That's the only sense in which the Higgs boson gives other particles mass: you start with a theory that describes massless particles, add in some math for the Higgs boson, and you wind up with a theory that allows massive particles. But it's not true that real particles in the universe physically derive their mass from the Higgs boson. It's just that the Higgs boson needs to be there for our theory to be consistent.
The Standard Model is still around, by the way, and it still describes all the known particles and forces (except gravity) exceedingly well, as long as the Higgs boson is included. So if the Higgs boson is discovered, physicists will have confirmed that the Standard Model is basically correct. But if we can rule out the existence of the Higgs boson, then clearly the theory is wrong. Either someone needs to find a different way to patch it up to include masses for the other particles, or we'll need to start from scratch and develop a brand new theory, which would keep a lot of people busy for a very long time :wink:
To be technically correct, we should say that the "Higgs Field" gives particles their masses. The particle we call the "Higgs Boson" is only one part of that field, and it's a different part of the field than the part that gives mass; rather it's a part of the field that is required for consistency reasons, as you said. Thanks for the post!
In Wilczek's book "The lightness of being" he is highly dismissive of the Higgs Boson and it having any significant value to theory.
I would rather say that the Higgs boson is the elementary particle (that creates a lot of problem in the SM such as triviality, naturalness, etc...) and the Higgs mechamisn is the possibility of having a scalar condensate that spontaneously breaks SU(2)*U(1) -> U(1). In this sense, a top quark condensate is a kind of Higgs mechanism, but free of elementary scalar boson (which would be better !)
  • · Replies 19 ·
  • · Replies 19 ·
