Not getting proper gain in opamp LM324N
by arunbhaskar
Tags: gain, lm324n, opamp, proper
arunbhaskar
arunbhaskar is offline
#1
Feb17-10, 09:00 AM
P: 9
I used LM324N(4 opamps on 1 chip) from ON semiconductor to build an Instrumentation Amplifier circuit. I chose the values of the resistors so as to give a gain of 640. But when i checked the gain on the CRO the gain was around 175. What problem could this be?
Datasheet link:http://www.onsemi.com/pub_link/Collateral/LM324-D.PDF
Phys.Org News Partner Engineering news on Phys.org
Lifting the brakes on fuel efficiency
PsiKick's batteryless sensors poised for coming 'Internet of things'
Researcher launches successful tech start-up to help the blind
Bob S
Bob S is offline
#2
Feb17-10, 10:31 AM
P: 4,664
What impedance is the output driving? What is your Vcc? Please post your circuit.
Bob S
arunbhaskar
#3
Feb18-10, 10:27 PM
P: 9
I used this circuit:
http://img195.imageshack.us/img195/9979/instamp.jpg
I observed the output directly across the CRO.
So don't have any idea about output driving impedance...
berkeman
berkeman is online now
#4
Feb19-10, 12:34 AM
Mentor
berkeman's Avatar
P: 39,638
Quote Quote by arunbhaskar View Post
What voltages are you using for your power supply rails? What voltages are your inputs? (not super-important for experimenting, but what are you doing to tie off the 4th LM324?)
Proton Soup
Proton Soup is offline
#5
Feb19-10, 02:16 AM
P: 1,070
that fig 13 equation is missing something
arunbhaskar
#6
Feb19-10, 07:56 AM
P: 9
LM324 has compatibility for split supplies and single supply.
I used split supplies +12V and -12 V. Yeah I forgot to mention that I wasn't getting the output with +5V and ground. I'm sorry but I'm very new to op-amps. I left all pins of op-amp 4 open.
What do you mean by tie off? Am I supposed to connect the pins of opamp which is not being used?
arunbhaskar
#7
Feb19-10, 08:02 AM
P: 9
I did the experiment on a trainer kit and rigged up the circuit using patch cords. Is there a chance that I'm not getting proper gain because of noise picked up by the cords?
berkeman
#8
Feb19-10, 01:15 PM
Mentor
berkeman's Avatar
P: 39,638
It's good practice to tie off unused gates and opamps/comparators/etc. In this case, just ground the + input and configure it as a follower.
On your gain question, what is your input signal (both differentially and common-mode)? With your target gain, what would that give you at the output?
Adjuster
Adjuster is offline
#9
Feb19-10, 05:13 PM
P: 206
Could you also indicate the frequency and level of the input signal. The LM324 has only 1MHz unity gain bandwidth, along with fairly modest slew rate capability - see datasheet enclosed.
Your circuit uses three amplifier cells, and I can't say exactly what the bandwidth would be by just looking at it, but I would guess that it won't be more than a few kHz for a gain of 640. Perhaps therefore what you are seeing is a frequency limitation.
MThornton
MThornton is offline
#10
Feb20-10, 06:40 AM
P: 28
with lm324 you must ensure your circuit operating voltages stay well clear of the supply voltages. This is not a rail-to-rail op-amp.
With an instrumentation amp circuit show, it is very important to match the like-value resistors as closely as possible.
Bob S
Bob S is offline
#11
Feb20-10, 12:55 PM
P: 4,664
You should start out with C = a = b = 1, and R = R1 = 10k, and then increase C to 5, and a and b to ~10. This will give a gain of ~5 x 21 = 105. You should avoid any feedback resistors less than ~ 2K or or over ~100K. The gain-bandwidth product of the LM324 is ~1 MHz, so for a gain of 175, you should expect a small-signal bandwidth of ~5 KHz.
Bob S
arunbhaskar
#12
Feb21-10, 10:08 AM
P: 9
What are rail to rail ICs. I tried to find out on the internet but didn't find a satisfactory explanation. Can anyone explain the exact meaning of rail to rail...
berkeman
#13
Feb21-10, 12:32 PM
Mentor
berkeman's Avatar
P: 39,638
That refers to an opamp that can swing its output voltage very close to the power supply rails, and may also accept input voltages that are close to the power supply rails.
So for example, if you are running the opamp with +/-12V supply rails, the inputs and outputs can swing very close to those supply rails.
The original LM741-type opamps were not able to do this, because they were made up of bipolar transistors and needed some headroom from the rails at their inputs, and could not drive their output to more than a volt or two from the rails. The newer CMOS opamps, at least the more expensive ones, can have much closer to rail-to-rail performance.
Register to reply
Related Discussions
opamp design Electrical Engineering 12
Opamp replacement Electrical Engineering 1
What is the difference between DC Gain and Gain Constant? Electrical Engineering 0
OpAmp Question - Max Gain? Engineering, Comp Sci, & Technology Homework 10
Help with this OPAMP CKT Engineering, Comp Sci, & Technology Homework 9
