Determining 4-vector character of a 4-tuple
  • Thread starter jmcvirgo
  • Tags
    4-vector
In summary, the conversation discusses how to show that a given 4-tuple is a 4-vector when told that its scalar product with any 4-vector is a Lorentz scalar. This can be proven by applying the definitions of the scalar product and using matrix notation to show that the given 4-tuple satisfies the tensor transformation rule. However, it is important to note that a 4-tuple cannot be a 4-vector on its own, as the assignment of 4-tuples to coordinate systems is what defines a 4-vector.
jmcvirgo
Suppose you're given a 4 tuple and told that its scalar product with any 4-vector is a lorentz scalar. How do I show that this implies the 4-tuple is a 4-vector?
Thanks
It can't be done unless you're told that its scalar product with any 4-vector is a scalar.
If the given 4-tuple is x and the (arbitrary) 4-vector is y,
[tex]x_\mu y^\mu=x'_\mu y'^\nu=x'_\mu\Lambda^\mu{}_\nu y^\nu[/tex]
[tex]x_\mu=\Lambda^\mu{}_\nu x'_\mu[/tex]
Now do some raising and lowering of indices and apply a Lorentz transformation to solve for x', and you're done. This post should help with the notation.
Just apply the definitions on the <scalar> product. Denoting by F the matrix the 4-tuple (index down) uses to transform under a Lorentz group element, you'll end with a matrix equation
[tex] \mathbb{F} \Lambda = \mbox{1}_{4\times 4} [/tex].
Since [itex] \Lambda [/itex] is invertible, the conclusion follows easily.
Here's how I would do it in matrix notation:
[tex]x^T\eta y=x'^T\eta y'=x'^T\eta\Lambda y[/tex]
[tex]x^T\eta=x'^T\eta\Lambda[/tex]
[tex]\eta x=\Lambda^T\eta x'[/tex]
[tex]x'=\eta^{-1}(\Lambda^T)^{-1}\eta x=\eta^{-1}(\eta\Lambda\eta^{-1})\eta x=\Lambda x[/tex]
The fact that [tex](\Lambda^T)^{-1}=\eta\Lambda\eta^{-1}[/tex] follows from the definition of a Lorentz transformation, [tex]\Lambda^T\eta\Lambda=\eta[/tex]. Just multiply both sides with [tex]\eta^{-1}[/tex] from the right.
I suggest that you be a bit more careful with the terminology. A 4-tuple can't ever be 4-vector. In order to define a 4-vector you must specify a 4-tuple for each coordinate system. It's the assignment of 4-tuples to coordinate systems that defines a 4-vector, not a single 4-tuple. The assignment is of course usually done by specifying the 4-tuple that you want to associate with a specific coordinate system, and then explicitly stating that the 4-tuples associated with all the other coordinate systems are given by the tensor transformation rule.
Yes, that was sloppy of me. The 4-tuple I had in mind only has to be a continuous function of the coordinate transformation. But I wasn't thinking of it being confined by the tensor transformation rule.
1. What is a 4-vector?
A 4-vector is a mathematical construct used in special relativity to describe the position and momentum of an object in 4-dimensional spacetime. It is represented by a 4-tuple, with four components representing the object's position in the three dimensions of space and its position in time.
2. How is the 4-vector character of a 4-tuple determined?
The 4-vector character of a 4-tuple is determined by using the Lorentz transformation equations. These equations help to convert coordinates between different reference frames and allow us to calculate the 4-vector character of a 4-tuple in a given frame of reference.
3. What is the significance of determining the 4-vector character of a 4-tuple?
Determining the 4-vector character of a 4-tuple is important in understanding the behavior of objects in special relativity. It allows us to accurately describe an object's position and momentum in different reference frames, which is crucial in making accurate predictions and calculations in this branch of physics.
4. Are there any real-world applications of determining the 4-vector character of a 4-tuple?
Yes, there are many real-world applications of determining the 4-vector character of a 4-tuple. For example, it is used in particle physics to calculate the interactions between particles, and in astrophysics to study the behavior of objects in space. It is also used in the development of technologies such as GPS systems and satellite communication.
5. Is there any relationship between the 4-vector character of a 4-tuple and the concept of space-time?
Yes, the 4-vector character of a 4-tuple is directly related to the concept of space-time. In special relativity, space and time are considered to be interconnected, and the 4-vector character of a 4-tuple allows us to describe an object's position and momentum in this interconnected space-time. This concept is essential in understanding the behavior of objects moving at high speeds and in different reference frames.
  • Linear and Abstract Algebra
