Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Physics > General Physics
Reply
image The bounce of a tennis ball (clay v. hard court) Share It Thread Tools Search this Thread image
Old Feb18-10, 06:39 AM                  #1
hrhaahr
hrhaahr is Offline:
I'm trying to understand why tennis balls have a higher bounce on clay courts than on hard courts.
I understand that the amount of friction is greater on clay so as to slow the ball's vertical speed down and create a steeper angle of reflection.
But I don't see how that explains why the coefficient of restitution is higher on clay (0.85) than on hard court (0.80). From what I understand, that means that a ball dropped on to a clay court will retain more of it's speed after the bounce (85 percent) than a ball dropped on to a hard court (80 percent).
I understand why grass courts have the lowest coefficient of restitution (0.75). They are soft and so I suppose they 'withhold' more of the energy of the dropping ball. But aren't clay courts softer than hard courts? A ball dropping on a clay court sometimes even make a little 'dent' in the court surface, whereas hard courts (like Rebound Ace) should work precisely to re-bound the ball due to it's cement/rubber surface. No?
Anyway, I hope someone is able to clarify this for me.
Old Feb18-10, 08:25 AM                  #2
rcgldr
rcgldr is Offline:
Re: The bounce of a tennis ball (clay v. hard court)
The higher the friction of the surface of the court, the more the spin is increased when it impacts with the court, and the increase in angular momentum comes at the expense of linear momentum so the ball bounces at a more veritcal angle than it would on a court with less friction.
In the case of hard courts, there's some type of elastic material under or mixed in with the surface that affects the bounce. I recall that the Austalian open courts are different than the US courts, but don't remember which one has the more elastic surface and which one is "faster".
Old Feb18-10, 11:12 AM                  #3
hrhaahr
hrhaahr is Offline:
Right, I'm with you that far. The increased friction of clay courts help to 'redirect' the forward momentum of the ball upward causing a higher bounce (sorry for the lay terms, I'm no physicist).
But what if the ball has no forward momentum?
Let me explain what I fail to understand:
I'm reading Rod Cross' and Crawford Lindsey's "Technical Tennis" and it says that "the rules of tennis says a tennis ball must bounce vertically at about three-fourths of its vertical drop speed".
Further: "The ratio of the ball's vertical speed after the bounce to that before is known as the 'coefficient of restitution (COR)'".
Ok, so the COR varies, depending on the surface. It's 0.75 for grass, 0.8 for hard court, 0.85 for clay.
But these numbers are valid, are they not, even if I simply drop a ball from a meter's height, straight, in a 90 degree angle on to the court? And if I do so, there is no friction involved. The ball simply bounces straight up and down.
So how, without friction, can it be that a clay court has a higher COR? Is the surface 'harder' than hard court? Does clay have more of a trampoline effect? How is that possible when hard courts are made of rubber while clay courts are made of crushed brick?
Hope you can help me out here, I'm desperate to understand this :-)
Old Feb18-10, 12:13 PM                  #4
tiny-tim
tiny-tim's Avatar
Homework Helper 2009
tiny-tim is Offline:
Recognitions:
PF Contributor PF Contributor
Homework Helper Homework Helper
Smile Welcome to PF!
Hi hrhaahr! Welcome to PF!
From http://en.wikipedia.org/wiki/Tennis_court#Clay_courts
Clay courts
Main article: Clay court
Clay courts are made of crushed shale, stone or brick. The red clay is slower[clarification needed] than the green, Har-Tru, "North-American" clay. The French Open uses clay courts, unlike the other three Grand Slam tournaments of each year.
Clay courts slow down the ball and produce a high bounce[citation needed] when compared to grass courts or hard courts. This is because clay courts have more grab and when the ball lands there is more friction pushing against the ball's horizontal path, therefore slowing it and creating a higher bounce. For this reason, the clay court takes away some advantage of big serves, which makes it hard for serve-based players to dominate on the surface.
Old Feb18-10, 02:43 PM                  #5
rcgldr
rcgldr is Offline:
Originally Posted by hrhaahr View Post
Right, I'm with you that far. The increased friction of clay courts help to 'redirect' the forward momentum of the ball upward causing a higher bounce (sorry for the lay terms, I'm no physicist). But what if the ball has no forward momentum?
I don't know if they use drop test or test where the ball is moving forwards as some speed.
So the COR varies, depending on the surface. It's 0.75 for grass, 0.8 for hard court, 0.85 for clay.
They also use different balls for the different surfaces, so that would also have an effect.
ITF rules state that a vertical drop from 100 inches onto a concrete base, for a "type 2" ball, should result in the ball bouncing 53 to 58 inches, a much lower COR than you're quoting. See "standard" ball at this web site:
http://www.itftennis.com/technical/e...alls/index.asp
Old Feb19-10, 03:02 AM                  #6
hrhaahr
hrhaahr is Offline:
I guess maybe there's a difference between height and speed? The COR I'm quoting states that the ball's vertical speed after the bounce will be approximately three fourths of it's vertical drop speed.
So I guess the question I'm still left with is this:
If I drop a standard tennis ball directly on to a clay court and I do the same thing on a hard court with an identical ball from the same height, which ball would bounce higher? And, most importantly, why?
Old Feb19-10, 01:57 PM                  #7
rcgldr
rcgldr is Offline:
I would assume that the amount of deformation of the clay court or hard court would be minimal with a dropped ball, so almost all of the bounce would be due to the nature of the ball and not of the surface. If the clay court was pourous and covered with grains, then some energy could be lost embedding the grains into the surface. A grass court would produce a lower bounce because the grass would deform significantly.
image image
Reply
Tags
ball, bounce, clay, tennis
Thread Tools
Similar Threads for: The bounce of a tennis ball (clay v. hard court)
Thread Thread Starter Forum Replies Last Post
Angular Momentum before and after being hit with a ball of clay Qnslaught Introductory Physics 3 Nov17-09 08:14 AM
2d ball bounce problem Gil-galad Introductory Physics 1 Jun5-09 04:01 PM
Tennis Ball Vs Glass Ball Vs Rubber Ball kecontroversy Classical Physics 6 Jun20-08 02:29 PM
Tennis serve bounce - spin doubles, speed halfs, why? Skhandelwal Classical Physics 1 Jan21-08 11:10 PM
[SOLVED] Sticky Collision with Clay Ball and Rod Squashy Introductory Physics 3 Dec26-07 12:37 PM
Powered by vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. © 2010 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
