Register to reply
A weight supported by two ropes
by chudd88
Tags: ropes, supported, weight
Share this thread:
chudd88
#1
Feb21-10, 12:19 PM
P: 17
Two ropes are connected to a steel cable that supports a hanging weight as shown.
If the maximum tension either rope can sustain without breaking is 5000 N, determine the maximum mass m that the ropes can support.
2. Relevant equations
Newton's equations #1, #3.
3. The attempt at a solution
Let the left rope have tension T1, and the right rope have tension T2. So, the horizontal component of T1 is cos(60)*T1, which must equal the horizontal component of T2, which is cos(40)*T2. So:
cos(60)*T1 = cos(40)*T2
T1 = (cos(40) / cos(60)) *T2
T1 = 1.532*T2
So T1 has the greater tension.
The problem states that the maximum tension for either T1 or T2 is 5000N. So, since T1 has the greatest tension, we give it a tension of 5000N. This means that T2 has a tension of 3266N.
The weight of the block is equal to the sum of the vertical components of the two tensions. So:
w = sin(60)*T1 + sin(40)*T2
So we have:
w = sin(60)*5000N + sin(40)*3266N
w = 5035N
That's the answer I get. My book tells me the answer is 6400N. I'm not sure where I've gone wrong here.
Nevermind all of this. As it turns out, I was just screwing up the final calculation. sin(60)*5000N + sin(40)*3266N doesn't equal 5035N, as I indicated.
So, nothing to see here...
Phys.Org News Partner Science news on Phys.org
Bees able to spot which flowers offer best rewards before landing
Classic Lewis Carroll character inspires new ecological model
When cooperation counts: Researchers find sperm benefit from grouping together in mice
Register to reply
Related Discussions
Two ropes holding a weight. System is in equilibrium, how do I find T3? Introductory Physics Homework 2
Tension Problem (two ropes + weight) Introductory Physics Homework 7
Determine maximum allowable weight of a load supported by chains Mechanical Engineering 4
Determine the maximum allowable weight of a load supported by chains. Engineering, Comp Sci, & Technology Homework 1
Ropes, Tension, Weight, & Equilibrium Introductory Physics Homework 1
