Double Stub Matching Using Smith Charts
by xcvxcvvc
Tags: charts, double, matching, smith, stub
xcvxcvvc
xcvxcvvc is offline
#1
Feb22-10, 09:41 PM
P: 393
I'm going to class, and I'll ask my teacher. There is not sense in you using your time on this problem anymore, so don't! I'll post the answer to my question after I find it in case someone ever stumbles on this thread with the same question I had. OK HERE IS THE ANSWER: My teacher accidentally gave an unsolvable question :P.
A 50 ohm line is terminated in a 40 ohm load.
Two shorted stubs are to be used in parallel with the line to match the load and line. One stub should be located in parallel with the load , and the other should be located1/4 wavelength from the load.
Find the input impedance of each stub.
3. The attempt at a solution
I know the circle I drew is retarded looking, but it gets the point across. I plotted the normalized impedance(.8) and converted it to admittance. Next, I drew a unit circle shifted toward the load by .25 wavelengths. After that, I see no way I can add an imaginary admittance to my real 1.25 so that it will be on the predictive unit circle (in other words, so that when that total admittance is shifted .25 wavelengths toward the generator, it will be on the unit circle with 1 real, xL reactive.)
Phys.Org News Partner Science news on Phys.org
Better thermal-imaging lens from waste sulfur
Hackathon team's GoogolPlex gives Siri extra powers
Bright points in Sun's atmosphere mark patterns deep in its interior
Register to reply
Related Discussions
1/4 lambda stub Electrical Engineering 9
stub axle calculations help please! General Engineering 5
Smith Chart Engineering, Comp Sci, & Technology Homework 0
War may be criminal - GOP Sen Smith Current Events 36
Smith-Percell Radiation General Physics 0
