Cornstarch solution
by WiFO215
Tags: cornstarch
WiFO215
WiFO215 is offline
#1
Feb27-10, 09:49 AM
P: 413
I was playing around with cornstarch solution as I saw on T.V. that it had some really funny properties. It becomes hard when you hit it, but its soft if you go slow on it.
I was preparing some at home in two containers. In one container however, I added too much water. Having finished the cornstarch, I couldn't add more. So to get rid of this extra water, I tried to heat the solution, but instead of returning to normal, globules formed in the solution as it became thicker. I'm finding it very difficult to make it normal.
Why does this happen? What does adding extra water and then heating do to the mix?
Phys.Org News Partner Physics news on Phys.org
Physicists design quantum switches which can be activated by single photons
'Dressed' laser aimed at clouds may be key to inducing rain, lightning
Higher-order nonlinear optical processes observed using the SACLA X-ray free-electron laser
WiFO215
WiFO215 is offline
#2
Mar1-10, 12:39 AM
P: 413
Anyone?
pantaz
pantaz is offline
#3
Mar1-10, 10:01 AM
P: 586
Sounds to me like you simply cooked the cornstarch. If you want to remove water, just let the (uncooked) mixture sit, undisturbed, and the cornstarch will eventually settle, then just pour off some of the water.
Google "non-newtonion fluids" for more information, recipes and experiments.
Andy Resnick
Andy Resnick is offline
#4
Mar1-10, 11:41 AM
Sci Advisor
P: 5,468
Cornstarch solution
Quote Quote by anirudh215 View Post
Cornstarch in solution is an example of a dilatant (shear thickening) fluid:
http://en.wikipedia.org/wiki/Dilatant
The phenomenon is partially understood at best- hand-waving arguments about tangled polymers are usually invoked. It's a nonlinear effect, and part of a more general phenomena:
http://en.wikipedia.org/wiki/Non-Newtonian_fluid
Unfortunately, when you heated the solution, you most likely made some irreversible changes to the starch itself, causing the behavior you experienced. best to just start over- next time, mix the material much more slowly. It's a nonlinear effect, so there's a narrow range of concentration that will produce the dramatic effect:
http://en.wikipedia.org/wiki/Oobleck
WiFO215
WiFO215 is offline
#5
Mar2-10, 10:36 PM
P: 413
Quote Quote by Andy Resnick View Post
I see. So not many people have done research on this stuff yet? Is it an open topic?
Andy Resnick
#6
Mar3-10, 07:33 AM
Sci Advisor
P: 5,468
In as much as the nonlinear dynamics of materials is an open topic, yes.
Register to reply
Related Discussions
How to determine if the mixing of two solution would result in buffer solution? Biology, Chemistry & Other Homework 3
Draft paper deriving a non-empty, stationary, axisymmetric solution solution of Einstein's Equations, based on the Lorentz Force Law General Physics 15
[SOLVED] Draft paper deriving a non-empty, stationary, axisymmetric solution solution General Physics 16
Cornstarch and vegatable oil Chemistry 1
