Mass Percent Equation
by 00_Furon
Tags: equation, mass, percent
00_Furon
00_Furon is offline
#1
Feb28-10, 03:40 PM
P: 2
Brass, an alloy of Zn and Cu, reacts with hydrochloric acid as follows:
Zn (s) + 2 HCl (aq) → ZnCl2 (aq) + H2 (g)
Cu does not react with HCl. When 0.5065 g of a certain brass alloy is
reacted with excess HCl, 0.0985 g of ZnCl2 is eventually isolated.
What is the composition of the brass by mass? (i.e., m%Cu, m%Zn)
Phys.Org News Partner Science news on Phys.org
Cougars' diverse diet helped them survive the Pleistocene mass extinction
Cyber risks can cause disruption on scale of 2008 crisis, study says
Mantis shrimp stronger than airplanes
nobahar
nobahar is offline
#2
Mar3-10, 02:36 PM
P: 503
Gnerally, your required to make some kind of attempt if possible.
Register to reply
Related Discussions
mass percent related problems Biology, Chemistry & Other Homework 0
Percent Effect of variables in equation Engineering Systems & Design 2
Calculating the composition of vapor in mass percent Biology, Chemistry & Other Homework 1
Mass Percent Biology, Chemistry & Other Homework 2
[SOLVED] Osmotic Pressure & Mass Percent Biology, Chemistry & Other Homework 2
