Newton's Ring Experiment
by ppdjoy
Tags: experiment, newton, ring
ppdjoy
ppdjoy is offline
#1
Feb28-10, 03:51 PM
P: 3
In a Newton’s ring experiment, a plano-convex glass (n=1.59) lens having diameter 12.6cm is placed on a flat plate as in the figure.
When 608nm light is incident normally, 6 bright rings are observed with the last one right on the edge of the lens, at r.
(a) What is the thickness of the lens?
Answer in units of m.
(b) What is the radius of curvature of the convex surface of the lens?
(c) What is the focal length of the lens?
2. Relevant equations
t = (2n-1)λ / 4
3. The attempt at a solution
I'm using the above formula. But for some reason, I keep getting the question wrong. I'm not sure if my approach is wrong or what.
Can anyone suggest me some methods as to how I should approach this problem? Like any different formulas or something?
Thanks
Phys.Org News Partner Science news on Phys.org
Going nuts? Turkey looks to pistachios to heat new eco-city
Space-tested fluid flow concept advances infectious disease diagnoses
SpaceX launches supplies to space station (Update)
Register to reply
Related Discussions
Newton's Ring Apparatus and Refractive Index Introductory Physics Homework 7
Thompson's Jumping Ring with the ring in the centre of the solenoid Introductory Physics Homework 0
Ring theory - characterizing ideals in a ring. Calculus & Beyond Homework 2
Finding the B-field at a point outside ring of current IN Plane of ring Introductory Physics Homework 1
Mach's Principle and Newton's Pail Experiment? General Physics 4
