| Thread Closed |
Flow rate, time, height in MATLAB???? |
Share Thread | Thread Tools |
| Mar2-10, 09:50 AM | #1 |
A tank vertical sides and a bottom area of 100ft^2 is used to store water. The tank is initially empty. To fill the tank, water is pumped into the top at a rate given in the following table. Determine the water height h(t) at t= 10 min 2. Relevant equations time (min) = [0,1,2,3,4,5,6,7,8,9,10] flow rate (ft^3/min) =[0,80,130,150,150,160,165,170,160,140,120] 3. The attempt at a solution I am confused about the relationship between the water height and flow rate. This is what I tried: diff(flow rate)./diff(time) = x sum(x) = q q/100 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Flow rate, time, height in MATLAB????
| Calculating the change in flow rate with varied height. | General Physics | 0 | ||
| Expression for height of water as a function of time given flow rate in and out | Calculus & Beyond Homework | 1 | ||
| Matlab in applying Finite Difference for Temp. distribution/ rate of heat flow | Math & Science Software | 0 | ||
| Rate of flow - height of water problem | Differential Equations | 4 | ||
| HELP! relationship between rate of flow of water and height of water column | Introductory Physics Homework | 1 | ||
