| Thread Closed |
3D Least Squares Fit and some Linear Algebra |
Share Thread | Thread Tools |
| Mar4-10, 07:55 PM | #1 |
Hello,
I am trying to write an algorithm to calculate the Least Squares Fit Line of a 3D data set. After doing some research and using Google, I came across this document, http://www.udel.edu/HNES/HESC427/Sph...astSquares.pdf (section 2 in page 8) that explains the algorithm for It uses something from Linear Algebra I have never seen called Singular Value Decomposition (SVD) to find the direction cosines of the line of best fit. What is SVD? What is a direction cosine? The literal angle between the x,y,z axes and the line? For simplicity's sake, I'm starting with the points (0.5, 1, 2) ; (1, 2, 6) ; (2, 4, 7). So the A matrix, as denoted by the document is (skipping the mean and subtractions) [tex]A = \left \begin{array} {ccc} [-1.6667 & -1.1667 & -2.8333 \\ -2.0000 & -1.0000 & 3.0000 \\ -2.3333 & -0.3333 & 2.6667 \end{array} \right][/tex] and the SVD of A is [tex]SVD(A) = \left \begin{array} {ccc} [6.1816 \\ 0.7884 \\ 0.0000 \end{array} \right][/tex] but the document says "This matrix A is solved by singular value decomposition. The smallest singular value of A is selected from the matrix and the corresponding singular vector is chosen which the direction cosines (a, b, c)" What does that mean? Any help will greatly be appreciated. Note: I am working in MATLAB R2009a Thank you in advance! *NOTE* I POSTED THIS IN THE WRONG MATH FORUM AND CANNOT DELETE THE FIRST POST. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: 3D Least Squares Fit and some Linear Algebra
| Uncertainty of linear and non linear least-squares fit | Set Theory, Logic, Probability, Statistics | 6 | ||
| Linear Least Squares Fit? | General Physics | 1 | ||
| Linear Algebra: Least Squares and vectors | Calculus & Beyond Homework | 1 | ||
| Numerical Methods - Linear Least Squares, Non-Linear Least Squares, Optimization | Calculus & Beyond Learning Materials | 0 | ||
| Linear Regression, Linear Least Squares, Least Squares, Non-linear Least Squares | Linear & Abstract Algebra | 4 | ||
