Advantages of Trunnion Pipe Supports
  • Thread starter Ask1122
  • Tags
    Pipe
In summary, trunnion pipe supports are preferred for engine mounts because they do not over constrain and restrict all displacements but not all moments. They also allow for the addition of a steady-rest at the back for the final degree of freedom. This is achieved by using a pin inserted into a hollow support, preventing yawing and rolling but not pitching. They also restrict sideways motion on one of the supports and displacement in the vertical and axial directions, leaving only one degree of freedom. Trunnion supports are used to prevent over-constraining of the part.
Ask1122
52
Hi all, can someone please tell me what are the advantages of using a trunnion pipe support? I guess that since it is welded on the pipe, it will prevent pipe movements in any directions, but then why would you use a trunnion instead of an anchor?
Thank you!
We use trunnion supports a lot for our engine mounts. The nice thing about trunnion mounts is that they don't over constrain. They restrict all displacements, but not all moments. You can add a simple steady-rest at the back to grab the final degree of freedom.
I am not real familiar with piping supports, but I hope we're talking about the same thing.
Thanks for the reply, but I am not sure how it restrict only the displacements but not the moment?
These are what we call trunnion mounts
http://en.wikipedia.org/wiki/File:Belarus-Vitsebsk-Monument_to_Heroes_of_Patriotic_War_of_1812-6.jpg
...mostly. The engine usually has the female end, basically just a hollow support. A pin of some sort is typically inserted into them that allows them to rotating in the pins axial direction. They prevent yawing and rolling, but not pitching.
We typically only restrict sideways motion on one of them, and they both restrict displacement in the vertical and axial directions. That leaves only one DOF left, which we use a "kind-of-pinned" joint at some aft location.
We use them because we can prevent over-constraining our part.
What are trunnion pipe supports?
Trunnion pipe supports are a type of pipe support used in industrial applications to securely hold pipes in place. They consist of a trunnion, or pivot point, which allows the pipe to move and expand without causing stress or damage.
What are the advantages of using trunnion pipe supports?
There are several advantages to using trunnion pipe supports. First, they provide excellent support for pipes of various sizes and weights. They also allow for movement and expansion of the pipes, reducing stress and potential damage. Additionally, trunnion pipe supports are durable and long-lasting, making them a cost-effective option.
How do trunnion pipe supports compare to other types of pipe supports?
In comparison to other types of pipe supports, trunnion supports offer a higher load capacity and better flexibility for movement and expansion. They also require less maintenance and have a longer lifespan, making them a more reliable option in the long run.
What types of industries commonly use trunnion pipe supports?
Trunnion pipe supports are commonly used in industries such as oil and gas, chemical processing, power generation, and water treatment. They are also used in HVAC systems and in building construction for supporting large pipes.
Can trunnion pipe supports be customized for specific applications?
Yes, trunnion pipe supports can be customized to fit specific pipe sizes, weights, and materials. They can also be designed to accommodate different levels of movement and expansion, making them suitable for a wide range of applications.
  • Mechanical Engineering
