Is there a differnt way to write this expression?
  • Thread starter Thread starter Firepanda
    Expression
The discussion revolves around the expression f(z) = SUM [(-1)^n] with the sum running from n=0 to infinity. Participants are exploring ways to simplify or rewrite this expression, questioning its convergence and potential relationships to known functions.
  • Some participants question the convergence of the series, noting that the nth term does not approach zero. Others discuss the relationship between the series and the function e^(z^2), considering how to incorporate the alternating sign. There are attempts to express the series in terms of a geometric series and discussions about the form of the series.
The discussion is active, with participants sharing insights and attempting to clarify the nature of the series. Some have identified potential forms for the series and are exploring whether they can progress further or need to reconsider their approaches.
There are indications of confusion regarding the manipulation of series terms and the implications of introducing geometric series concepts. Participants are also reflecting on their previous attempts and the need to avoid similar mistakes in their reasoning.
Firepanda
f(z) = SUM [(-1)n
Where SUM = sum from n=0 to infinity
Looks to me like there isn't but there must be a simpler way to write that.
Thanks
It's divergent, isn't? The nth term doesn't approach 0.
The question is to write this power series as a function
z^(2n)/n! isn't equal to e^(z^2). The SUM of the series z^(2n)/n! is e^(z^2). That would be fine if the (-1)^n weren't there. Can't you think of a function that's a lot like e^(z^2) that will give you the alternating sign in the series?
I just keep getting into the routine of trying to simply it like before. Do you mean replace e^(z^2) or multiply in some function f(z)/f(z)?
(-1)^n*z^(2n). Can you think of a way to write that as r^n for some number r? What would r be?
ahh yes
For the 2nd part I have it down to
z-2 SUM (-1)n.(z2/4)n+1
Is there anyway I can progress from here or should I go back and try a different way?
It's a geometric series.
(z2/4)n+1 starting at n=0
= 1/(1-z2/4) - 1
=> Series = z-2 SUM (-1)n/(1-z2/4) + (-1)n+1
= 1/(1-z2/4) - 1
You just did the same wrong thing you did in the first problem. You replaced a term is the series with the sum of a series. And you missed the cue to do the same thing you did with the (-1)^n in the first problem. You series has the form a*r^n. r just might have a (-1) in it.
ah yes, i have my r now thanks, was simple after that!
Thanks a lot
