Mechanics Problem HELP!
by mikex24
Tags: mechanics
mikex24
mikex24 is offline
#37
Mar21-10, 09:16 PM
P: 87
yes i understand it.
PhanthomJay
PhanthomJay is offline
#38
Mar21-10, 09:24 PM
Sci Advisor
HW Helper
PF Gold
PhanthomJay's Avatar
P: 5,959
You can't pass the module with a 1 hour lecture. Unless you studied it on your own for many many hours after that. I don't know what you were expecting.
mikex24
mikex24 is offline
#39
Mar21-10, 09:27 PM
P: 87
it is not just bending on beams. There are many others such as second moment of area, kinetics, kinematics...
PhanthomJay
#40
Mar21-10, 09:33 PM
Sci Advisor
HW Helper
PF Gold
P: 5,959
Quote Quote by mikex24 View Post
it is not just bending on beams. There are many others such as second moment of area, kinetics, kinematics... but because this is an assignment and the lecturer thinks that the students are experts with one hour lecture and one hour seminar on bending beams.. :( .
This problem as written has nothing to do with bending of beams. It asks for the shear and moment diagrams. The bending stress is simple, it 's just Mc/I. It sounds to me like you enrolled in a course without having the necessary prerequisite courses on the basics.
mikex24
mikex24 is offline
#41
Mar21-10, 09:35 PM
P: 87
Hello. I did some work and i need some tips for the next stage:
mikex24
mikex24 is offline
#42
Mar22-10, 12:41 PM
P: 87
I found the P1, P2, Mx, Qx
P1=20*2.15=43 N and it acts (2.15/2)+0.1=1.175 from the right end
P2=0.5*2.15*20=21.5 N and it acts (2.15/3)+0.1=0.816 from the right end
therefore P1+P2=Qx therefore Qx=64.5 N
so Mx=(43*1.175)+(21.5*0.816)= 68 Nm
therefore R=Qx=64.5 so Rcos15=62.3 and Rsin15=16.69
is that right? Cheers
PhanthomJay
#43
Mar22-10, 09:28 PM
Sci Advisor
HW Helper
PF Gold
P: 5,959
I'm glad you did not give up. Those values are correct, but i'm not sure why you call it Qx and Mx; the value you calculated for Qx is the vertical upward internal reaction at the right end of the horizontal beam (call it Q), and the value for Mx (call it M_right) is the internal clockwise moment at the right end of the horozontal beam. You still need to calculate the moment at the support. Now you need to draw the shear and moment doagrams as requested iin the problem..
mikex24
mikex24 is offline
#44
Mar22-10, 10:04 PM
P: 87
yes... here is the trouble. how can i found the moment on the fixed support(i think that is the same as the upward but in different direction)?
PhanthomJay
#45
Mar22-10, 10:44 PM
Sci Advisor
HW Helper
PF Gold
P: 5,959
l already gave you the equation for the moment at the fixed base support, in a sketch many posts ago. That is one way of doing it. But you need to calculate the values of x1 and x2, using basic geometry and trig.
mikex24
mikex24 is offline
#46
Mar23-10, 12:33 AM
P: 87
I did it. I found 64.5. I have to use the Rcos15 to find the x1 and x2?
mikex24
mikex24 is offline
#47
Mar23-10, 05:45 AM
P: 87
I use trigonometry and i found the x1 and x2 and i found the Mx at the fixed end of the framework which is : 134.805. ??
mikex24
mikex24 is offline
#48
Mar23-10, 05:49 AM
P: 87
What is the total plan and the next stages to solve this question?
PhanthomJay
#49
Mar23-10, 06:17 AM
Sci Advisor
HW Helper
PF Gold
P: 5,959
Please tell me how you would go about drawing shear and moment diagrams for the more simple case of a simple beam supported at each end with a uniformly distributed load. You have to get back to the basics............as i tried to note before, if you don't understand the basic steps, you will find drawing the shear and moment diagrams for this problem quite difficult.........and I'm not about to do it for you...........we are here to assist, but you must do the work..............
mikex24
mikex24 is offline
#50
Mar23-10, 06:22 AM
P: 87
i know that we have to cut the beam in x values to find in each point of x the value of moment and force. ?
for A-B the Mb and Qb will zero
then if i start from the left of the beam
then for B-C part
i will cut the just after the first force which is the force of triangular
the problem i found there is that is that i cant find many unknows x to have quadtrative equation because always the unknows x is just one like 8x-3 and this is a straight linear equation. ??
Joshsamuel117
Joshsamuel117 is offline
#51
Mar23-10, 06:38 AM
P: 1
We've got a similar problem(the exact same) to this one for our assignment and we were wundering if the strength of the tubeing by workin out the external area then taking the internal area away from it to get the area of the piping and then divide the values of the forces we got from the wieght of the billboard. we did this but the values we got were extremly small compared to the yeild stress of the low carbon steel. the value we got was 0.2MNm^-2 but the yeild stress is 300MNm^-2 thanks for any help you can give
PhanthomJay
#52
Mar23-10, 10:24 AM
Sci Advisor
HW Helper
PF Gold
P: 5,959
Quote Quote by Joshsamuel117 View Post
This is the 3rd separate post on this same problem, and I need to know up front where this assignment is coming from, and for what purpose it is being assigned, before we can provide additional assistance.
mikex24
mikex24 is offline
#53
Mar23-10, 10:27 AM
P: 87
This is an assignment of a UK university. As you can there are many person with difficulties on this assignment as we teached only 2 hours on this module for the beams..
PhanthomJay
#54
Mar23-10, 10:51 AM
Sci Advisor
HW Helper
PF Gold
P: 5,959
This is an assignment of a UK university man. As you can there are many person with difficulties on this assignment as we teached only 2 hours on this module for the beams..
If this is a homework assignment, we can offer help, but not solutions, and even then, it is assumed that the 'UK university man' does not object to your seeking outside help. If this is a take home exam that determines whether you pass or fail a course, for example, then we cannot provide help, per Forum rules. That would be , in a sense, cheating. That is why I am being a bit cautious here, and I need you and the others to be up front and honest about this.
Register to reply
Related Discussions
AP Mechanics Problem Introductory Physics Homework 1
Mechanics problem Introductory Physics Homework 5
Solid mechanics problem (pretty much a static problem) Introductory Physics Homework 1
mechanics problem Introductory Physics Homework 1
Mechanics problem Introductory Physics Homework 1
