Solving Inorganic Compounds Homework: Sulphuric Acid & Water Vapour
  • Thread starter Thread starter Adam2987
The discussion revolves around a homework problem involving the neutralization of sodium hydroxide with sulfuric acid and the calculation of water vapor produced in the reaction. Participants explore the stoichiometry of the reaction, the application of the ideal gas law, and the use of fractional coefficients in chemical equations.
  • Homework-related
  • One participant calculates that 12.3 g of sulfuric acid will neutralize 10.0 g of sodium hydroxide, using the molar ratio from the balanced chemical equation.
  • Another participant questions how much water is produced in the reaction, seeking clarification on the stoichiometric relationships.
  • There is a discussion on the application of the ideal gas law (PV=nRT) to calculate the volume of water vapor produced, with some participants expressing confusion about the correct approach.
  • One participant expresses uncertainty about whether to calculate moles of water independently or use the moles of sodium hydroxide already calculated.
  • Fractional coefficients in chemical equations are discussed, with participants sharing their difficulties in understanding and applying them.
  • Clarifications are made regarding the use of stoichiometric coefficients to determine the amounts of reactants and products in a balanced equation.
  • One participant realizes a mistake in their application of the ideal gas law, leading to a significant change in their calculated volume of water vapor.
Participants generally agree on the stoichiometric relationships in the reaction, but there is disagreement and confusion regarding the application of the ideal gas law and the use of fractional coefficients. The discussion remains unresolved on the best approach to calculate the volume of water vapor produced.
Some participants express uncertainty about the correct application of the ideal gas law, particularly in relation to the conditions of temperature and pressure provided in the problem. There are also unresolved questions regarding the use of fractional coefficients in balancing chemical equations.
Adam2987
1.a, How many grams of sulphuric acid will neutralize 10.0g of sodium hydroxide?
b, What volume of water vapour at 100 degrees celsius and 110 kPa would also be produced?
a) my answer for a is 12.3 g, didn't have issues with this question
b) I know I'm suppose to use PV=nRT I just can't figure out how to go about the question, do I calculate the number of moles for H2O first? Or do I use one of the moles from the previous calculations? Don't need the full answer just a push in the right direction.
Can't say I understand your problem.
How much water is produced in the reaction?
Let me show you my work.
for a)
H2SO4 + 2NaOH ----> Na2SO4 + 2H2O
NaOH H2SO4 molar ratio 2:1
2 mol 1 mol
Molar mass NaOH:
Na: 1 x 23.0 g = 23.0g
OH: 1x 17.0g = 17.0g
= 40.0g
moles of NaOH reacted: (10.0g)/(40.0g/mol) = 0.250 or 2.50x10^-1 mol
Let x = mol of H2SO4 x/1 = 0.25/2 = 0.125
0.250 mol x mol
2NaOH --> H2SO4
2 mol 1 mol
Molar Mass H2SO4 = 98.1g
Thus, mass H2SO4 produced:
= 0.125 x 98.1g/mol
= 12.3g
Therefore 12.3 g of sulphuric acid will neutralize 10.0 g of sodium hydroxide
b) What volume of water vapour at 100 degrees celsius and 110 kPa would also be produced?
Here's what I did:
PV=nRT, therefore, V = P/nRT : V = 110kPa/(0.250mol)(8.31kPa x L / mol x K) (373K)
V= 0.142L
Therefore 0.142 L of water vapour would be produced.
Now if this is correct, I'm not sure why. A friend of mine told me to focus on the NaOH mol as it was directly involved in the question. Not sure what it meant, so if this is correct, an explantion would be great :D
Also, any explanation on fractional coeffiecients would be great, I've read pages and pages about it, but I'm not sure how I can produce them when creating compounds, in my opinion it's easier to just use coefficients but the chapter in my textbooks says fractional coefficients are a lot easier in compund design and understanding, I just can't seem to understand it's simplicity if there is one.
You dodged my question, at least partially.
Correct.
= 0.125 x 98.1g/mol
= 12.3g
Correct.
Here's what I did:
You have not shown where did the 0.25 mole of water came from - that's what I was asking about. But you are right - for each mole of NaOH neutralized there is one mole of H2O produced, so if you started with 0.25 mole of naOH you have produced 0.25 mole of water - that's the amount of substance that will be now treated as a gas.
But you are using wrong formula, so the result is off. PV=nRT so V is NOT P/nRT.
No idea what you mean - please give an example.
Me and you have the same question, the question as stated is all the information I've been given, in my original post I asked if I was suppose to calculate the moles of water on my own or use a previous molar quantity, a friend told me to use the mol of NaOH with no explanation. Not trying to doge your question, I just can't answer it.
as for my fractional coeffiecient issues, here's an example
Al + 3/2 H2SO4 ---> 1/2 Al2(SO4)3 + 3/2 H2
If I were to solve the first part, how do I go about getting 1/2 Al2(SO4)3 + 3/2 H2
I fully understand balancing equations using coefficients, but this fractional coefficient stuff just makes my brain hurt. I just don't understand how you go about getting 1/2 an Al2 ion.
If I'm not suppose to use PV=nRT to calculate the volume of water vapour produced, would I use a mass-volume calculation? I'm unsure because this ust really seemed like a PV=nRT situation
Do you know how to read balanced reaction equation? Stoichiometric coeffcients tell you what is ratio of moles of ALL substances involved, doesn't matter if they are reactants or products. To calculate amount of water you use exactly the same approach you used to calculate amount of sulfuric acid. Look at the reaction equation, look at the stoichiometric coeffcients, use them for calculations.
Yes you can.
Al + 3/2 H2SO4 ---> 1/2 Al2(SO4)3 + 3/2 H2If I were to solve the first part, how do I go about getting 1/2 Al2(SO4)3 + 3/2 H2
You don't get half of an atom, but once you have the equation balanced in fractional coefficients you can always convert it easily to whole numbers. So don't worry too much.
If you try to balance
H2 + O2 -> H2O
you can assume there was one molecule of oxygen - then it is obvious there are two molecules of water produced and that means two molecules of hydrogen were necessary. However, if you start assuming there was one molecule of hydrogen it follows that you produced one molecule of water - but that in turn means only half a molecule of oxygen was used:
H2 + 1/2O2 -> H2O
Just multiply by two to get rid of fraction and everything is OK.
Note that in this case it was more or less obvious that starting with oxygen will not yield fractional coefficients. In the case of more complicated reaction equations it is not always that obvious and sometimes you have balanced everything else and you are left with the last element - and you can either throw away everything already done and start again, or use fractions to balance - and get rid of them later. Guess which approach is faster.
Thank you for the help, much appreciated. Fractional coefficients make more sense now haha. I understand what you're saying about how to go about calculating the water vapour, but when I reflect on my textbook if I go about the way I got H2SO4, It would have to be at STP no? But because we are given a temperature and a pressure, we have to use PV=nRT
Atleast that's what my text says. I go about it mathematically, I still get the same answer. The book also makes reference to PV = nRT therefore V = P/nRT. So combining what you say and what the text says, I'm even more confused than I was before. The only difference now is that I know why we make reference to NaOH, which clears up a lot.
Thank again for your help, much appreciated.
PV=nRT works for gases, not for everything. At 100 deg C water is gaseous, hence you can use ideal gas equation to calculate its volume. Sulfuric acid is liquid at these temperatures and its volume is not that easy to calculate.
Check your math, you got it reversed.
oh... @!$## V = nRT/P so my answer would change drastically, gives me 7.05 L
haha whoa thanks for pointing that out
