Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Mathematics > Calculus & Analysis
Reply
image Gradient: Normal vs Direction of Increase Share It Thread Tools Search this Thread image
Old Mar10-10, 07:47 AM                  #1
thepopasmurf
thepopasmurf is Offline:
Hi,
I'm having trouble understanding what exactly the gradient of a scalar field represents. According to wikipedia and the textbooks I have it points in the direction of greatest increase and has a magnitude of greatest increase. This by itself seems fine. However, I have also been using it to find the normal of a surface and I don't understand how it can be both.
Also, do the properties( eg, what it represents) of the gradient change as you change dimensions and how does it work on a simple 2d graph?
Old Mar10-10, 08:47 AM                  #2
Tinyboss
Tinyboss is Offline:
Re: Gradient: Normal vs Direction of Increase
The gradient is perpendicular to the level sets of a function. So if your surface is given by f(v)=c, the normal at v is given by the direction of the gradient at v.
Old Mar10-10, 09:36 AM                  #3
quasar987
quasar987's Avatar
quasar987 is Offline:
Recognitions:
PF Contributor PF Contributor
Homework Helper Homework Helper
It all comes from the formula <v,w>=|v||w|cosθ where θ is the angle between v and w.
Let F:R³-->R be a function. By looking at the definition of DF(x)v for |v|=1 (the derivative of F at a point x in the direction of the vector v), we agree that this number represents the rate of change of F at x in the direction v. On the other hand, the gradient of F at x is defined as the (unique) vector ∇F(x) such that DF(x)v=<∇F(x),v> for all vectors v.
So to ask in which direction is F increasing the most rapidly at x is to ask which vector v of unit lenght (|v|=1) maximizes the value of DF(x)v. But DF(x)v=<∇F(x),v>=|∇F(x)||v|cosθ=|∇F(x)|cosθ, with cosθ taking values between -1 and 1. Clearly, |∇F(x)|cosθ is largest when cosθ=1; i.e. when θ=0. That is, when v points in the direction of ∇F(x)!
Now, consider S a surface in R³ that is realized as the level set F=c of F. That is, LaTeX Code: S=F^{-1}(c) for some constant c. Take x a point in S. By definition, a tangent vector to S at x is a vector v of the form LaTeX Code: v=\\gammasingle-quote(0) for some curve LaTeX Code: \\gamma:]-1,1[\\rightarrow S on S with LaTeX Code: \\gamma(0)=x . Notice that for LaTeX Code: v=\\gammasingle-quote(0) a tangent vector to S at x, the derivative of F at x in the direction v vanishes:
LaTeX Code: DF(x)v=DF(x)\\gammasingle-quote(0)=\\frac{d}{dt}_{t=0}(F\\circ\\g  amma)(t)=0
The second equality is the chain rule and the third equality is because the map LaTeX Code: (F\\circ\\gamma)(t) is the map LaTeX Code: t\\mapsto c .
Ok, so in terms of the gradient, what does this tells us? It tells us that 0=DF(x)v=<∇F(x),v>=|∇F(x)||v|cosθ, so cosθ=0, so θ=±90°. That is, ∇F(x) and v are perpendicular. By definition, this means ∇F(x) is perpendicular (or normal) to the surface S at the point x.
image image
Reply
Tags
gradient, vector calculus
Thread Tools
Similar Threads for: Gradient: Normal vs Direction of Increase
Thread Thread Starter Forum Replies Last Post
Gradient and normal azay Calculus & Analysis 2 Mar5-10 08:58 AM
gradient of a scalar field in a given direction mudkip9001 Calculus & Beyond 4 Nov2-09 05:44 PM
How can gradient be zero if its a normal vector? aaryan0077 General Math 1 Jul5-09 10:49 AM
Normal to a Tangent Plane of graph F/Gradient of F sinClair Calculus & Beyond 0 Feb26-08 09:30 PM
Direction of the gradient daudaudaudau Calculus & Analysis 4 Jan1-08 06:12 PM
Powered by vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. © 2010 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
