Register to reply
How do magnetic fields do no work?
by imaloonru
Tags: fields, magnetic, work
Share this thread:
Studiot
#19
Mar15-10, 02:34 AM
P: 5,462
can be modeled as macroscopic bound currents.
The operative word here is model.
Born2bwire
#20
Mar15-10, 02:44 AM
Sci Advisor
PF Gold
Born2bwire's Avatar
P: 1,777
Quote Quote by Studiot View Post
Well we could use the original microscopic atomic loop currents as well, it's no different. In fact I recollect that Griffiths does a treatment of this in his text. We just take the shortcut of superposition to bring it up to macroscopic bound currents. This is the relationship between magnetization and the current densities in Maxwell's equations.
varga
#21
Mar15-10, 02:44 AM
P: 64
Quote Quote by Phrak
Yet, one simple thought experiment seems to say the Lorentz force is wrong or incomplete (it isn't):
A charge neutral, ring of current is subject to a force in a time invariant magnetic field. To obtain the magnetic field we can use another axially aligned ring of current.
Who can explain the work done by one fixed ring of current, upon on the other, using the Lorentz force equation?
I agree Lorentz force is correct and complete and if what I previously said is true I should be able to explain the work done in any setup involving any em charges, fields or forces.
Can you give full details about these rings of current, what is initial condition in terms of electron velocity in the 'primary' ring and what is observed effect in the 'secondary' ring in terms of electron displacement or velocity. What is their exact relative position, orientation and size.
gabbagabbahey
#22
Mar15-10, 02:50 AM
HW Helper
gabbagabbahey's Avatar
P: 5,003
Quote Quote by Phrak View Post
Griffiths' Introduction to Electrodynamics for one. See the discussion immediately prior to eq 6.3 (in the 3rd edittion) along with the outline of problem 6.22 from that text.
Phrak
#23
Mar15-10, 02:50 AM
P: 4,512
It's a little late for me varga. Besides, I want to see if experts here can rise to the challenge.
gabbagabbahey, I don't have that text. What does it say?
Studiot
#24
Mar15-10, 03:01 AM
P: 5,462
Interesting that there is another current thread in this forum and a good many textbooks that suggest the opposite.
Born2bwire
#25
Mar15-10, 03:44 AM
Sci Advisor
PF Gold
Born2bwire's Avatar
P: 1,777
Assuming a uniform current, the force on a a loop current is
[tex] \mathbf{F} = I \oint \left(d\mathbf{l}\times\mathbf{B}\right) [/tex]
Which is directly from the Lorentz force by noting that the charge is Idl. In a uniform magnetic field, the net force is zero but not so in a nonuniform field. For certain problems this may not be too difficult. For example, Griffiths' gives the net force if you place a current loop directly above a solenoid such that the solenoid and current loop share the same axial axis. The calculated net force is along the axial direction. Since the charges are flowing in the plane normal to this direction, the initial force direction gives 0 work. This follows from the fact that the force is acting directly on the moving charges, which means that it must be acting along a direction that is not going to contribute to the work. While the initial force comes from the magnetic field alone in the frame of the current loop, once the current loop deflects then there is a time-varying magnetic field and thus a time-varying electric field as well. The same could be said about a single electron in a spatially varying, but time static, magnetic field. From the electron's frame of reference, the spatial variations of the magnetic field appear as a time-varying magnetic field and thus an associated time-varying electric field appears as well.
EDIT: Quick thought occured to me. If we have a system where the lab frame only has a magnetic field, then given a reference frame that is traveling with velocity v, then the electric field in the reference frame is
[tex] \mathbf{E} = \mathbf{v}\times\mathbf{B} [/tex]
Neat huh?
I think a lot of this discussion is mainly a point of pedantics. I don't think anyone is going to seriously try and work every problem from the perspective of electric field work. But I think that the underlying physics that mediate the energy from the magnetic field to a system are rather subtle and seem to cause a lot of confusion. I have not seen in the literature that the magnetic field's force can give rise directly to work. Instead, I have always read that there are subtle mediations that involve field transformations and such.
varga
#26
Mar15-10, 03:47 AM
P: 64
Quote Quote by Born2bwire
There is no stipulation that you need two magnetic fields to create a force. A single magnetic field will result in a force when any charged particle passes through the field.
According to 2nd and 3rd Newton's law of motion we can not have INTERACTION (force) without there being two of something that can interact. In your example you too have a force only because you have two fields interacting:
1. moving charge is one magnetic field (ignoring spin dipole moment)
2. "(charge) passes through the field" - this describes the SECOND field
Force describes the change in momentum. Work is the change in momentum along the object's trajectory.
Agreed.
The magnetic field can only change the charge's direction, but not its speed. And again, you do not need two fields, only one field.
CHANGE in DIRECTION is ACCELERATION is CHANGE in VELOCITY vector. I'd like to see example where there's force and only one field.
In the case of the two current carrying wires, as I explained earlier, the work is done by the electric fields, not the magnetic fields. This is because in the frame of the charges, the magnetic fields transform to electric fields which provide a force that allows for work to be done. This is an example shown in many textbooks such as Griffiths or Grant & Phillips.
Why are you talking about special relativity and why change reference frame all of a sudden? Why not look at electric field from their reference frame when they exist as magnetic fields then? That is arbitrary and inconsistent, in classical physics we have absolute reference frames and they work just fine for these purposes.
We are talking about classical mechanics and classical electrodynamics, in this framework we can explain these experimental setups completely from our (observer) reference frame, just like we do for all the rest of classical physics, and so there is no reason to involve any other more abstract and complicated explanation, which I find flawed anyway.
We can measure displacement of those parallel current caring wires and it perfectly matches to the magnitude of magnetic force as given by Ampere's force law or Lorentz force equation and Biot-Savart law, so why change anything about it if it works as it is?
Two parallel wires, if electric fields of electrons cancel due to superposition with positive electric fields of protons in these wires, then we are obviously left with some other force here, and what kind of force would be the one that can act in two directions in the same time anyway - the very fact that you have two independent and different displacements suggests you have two unique force vectors at work - two forces.
As for that page, thank you. Unfortunately there are statements there that are wrong according to everything I encountered in my education, and although that was quite some time ago, still I'm talking about basics like vector math and Newton's laws of motion, so I must raise my objections. But I'm not surprised those wired conclusions were reached if the logic of it was derived from Maxwell's equations instead of from Coulomb's law, Biot-Savart law and Lorentz force equations.
- "Magnetic forces may alter the DIRECTION in which particle moves, but they can not speed it up or slow it down."
1. What "speed up" and "speed down" has to do with work done?
2. Is change of direction not displacement either with constant velocity or not?
This is the same as projectile motion or free fall under gravity field. You have to split the movement into VECTOR COMPONENTS. If bullet starts its trajectory horizontal to the ground, what does gravity do? It ALTERS THE DIRECTION. How? By causing displacement in the direction perpendicular to the motion of the bullet, yet we do not say gravity field can ONLY alter the direction, because "altering direction" is what DISPLACEMENT actually is if you look at the vertical component of the motion - vector calculus.
Take the Earth and its gravity field out of the equation and bullet moves straight as its gravity field has nothing to interact with and so we do not expect any gravity force, any change in velocity nor change in direction - Newton's 1st law of motion.
Born2bwire
#27
Mar15-10, 04:08 AM
Sci Advisor
PF Gold
Born2bwire's Avatar
P: 1,777
Quote Quote by varga View Post
There is no absolute reference frame in classical electrodynamics. Classical electrodynamics by definition satisfies special relativity. Avoiding to properly account for special relativity even when we are discussing non-relativistic velocities can give you incorrect answers because the fields ALWAYS transform using the Lorentz transformations.
Frame Dragger
#28
Mar15-10, 04:51 AM
P: 1,540
We are talking about classical mechanics and classical electrodynamics, in this framework we can explain these experimental setups completely from our (observer) reference frame, just like we do for all the rest of classical physics, and so there is no reason to involve any other more abstract and complicated explanation, which I find flawed anyway...
You have zero understanding of those "more abstract and complicated explantion[s]," which you continually demonstrate, while loudly making demands and generally being boorish. You endlessly make vague attacks on QM and SR/GR without providing sources or sound arguments. Every thread has you going down the same road regarding Electromagnetism and the same points you refuse to accept.
marcusl
#29
Mar15-10, 10:58 AM
Sci Advisor
PF Gold
P: 2,081
Quote Quote by Born2bwire View Post
Your example has two fields--one is the static field while the other is due to the charged particle's motion.
I think we can safely say that the "magnetic fields do no work" is an oversimplification of classical electrodynamics despite born2bwire's text.
Agreed. There is, for example, the work
[tex]W=\frac{1}{2}\int\vec{H}\cdot\vec{B}\kern+2pt dV[/tex]
done in bringing a magnetic field up from zero. As mentioned by others, this equation can be derived by considering the electric potentials that are generated by the time-varying currents needed to create the magnetic field. Note also that, for fields created by currents, this leads directly to the engineer's statement of stored energy in terms of inductance
[tex]U=\frac{1}{2}LI^2,[/tex]
and its extension involving mutual inductance when multiple linked coils are involved. Still, it is most convenient to write the work done in terms of magnetic fields, as above, and not the difficult and detailed equations involving time-varying fields and electric potentials.
If the fields in the equation above for work are from two coupled currents, then the derivative of work gives the force between the currents, as pointed out by Bob S. While much of the subsequent discussion of microscopic currents in a magnetized solid may be valid, it takes us out of the practical realm--in fact, truly correct treatment of microscopic magnetization is not even classical, but requires quantum mechanics. In the classical world, on the other hand, problems involving magnetic matter are best handled through the magnetization M, which properly accounts for their bulk behavior.
In this construct, there is no question that magnetic fields can do work on magnetized solids. To return to two cases already considered, the linear force and the torque on a dipole in a field can be integrated to find the work done as the dipole moves. The general expression for the work done in all such cases is
[tex]W=\frac{1}{2}\int\vec{M}\cdot\vec{B}\kern+2pt dV .[/tex]
If you want references to cross-check Griffiths, take a look at ch. 5 in Jackson or ch. 8 of Smythe.
xlines
#30
Mar15-10, 11:17 AM
P: 96
Quote Quote by imaloonru View Post
I remember learning in Electrodynamics last year that magnetic fields don't actually do any work. I don't seem to remember any of the explanation behind that. Can anyone explain why magnetic fields do no work (ie. How they differ from electric and gravitational fields). Thanks!
I ran into interesting letter on the subject :
http://academic.csuohio.edu/deissler..._77_036609.pdf
I am planning for some time to clear this thing up in my head. A working solution I don't plan to defend too vigorously is that magnetic field can do work. Within CED answer is no. Reason this isn't so in real world is because field interacts with atomic dipoles which are quantized and can not adjust it's orientation perfectly to cancel working effect of field. Other reason is field interaction with spin which is, of course, not current loop to which classic no-work result applies.
varga
#31
Mar15-10, 12:14 PM
P: 64
Quote Quote by Frame Dragger View Post
You have zero understanding... without providing sources or sound arguments.
Ughh, look at your argument. I wanted to ignore your intrusion as you failed to specify anything in particular and even less make any actual arguments, but since I got some negative points regarding my previous post, as there is apperantly some "misinformation" there, then I decided to respond after all. To you I say, please WHAT is it you actually disagree about? I'll be happy to provide sources and answer all your questions, but what is it you are talking about? And to everyone else, I apologize for any misinformation and any false or ambiguous statements I made here, I did so only because it was written in my books and is my own (mis)understanding, but I will stand corrected as soon as someone actually points out what is it I am wrong about.
varga
#32
Mar15-10, 12:19 PM
P: 64
Quote Quote by marcusl
Let me say that I'm glad to finally see someone I agree with... at everything but this above. I do not think there is anything in QM that can come even close to describe (explain) orbital magnetic moment.
marcusl
#33
Mar15-10, 12:20 PM
Sci Advisor
PF Gold
P: 2,081
I just found this post by Vanadium50 in another thread
http://www.physicsforums.com/showthread.php?t=347539
that does a better job explaining my point than I am doing:
Quote Quote by Vanadium 50 View Post
I don't like teaching the meme "magnetic fields do no work." It is true, but it is not useful.
It's clearly true for a single charged particle: the Lorentz force law has the magnetic force perpendicular to the direction of motion, so the dot product of force and displacement is always zero. It's also clearly true that magnets can do work on each other.
The solution to this apparent contradiction is that complex objects like magnets are made up of many charges, and these charges exhibit both electric and magnetic forces on each other, and if one does the calculation carefully enough, it can be shown that the work actually comes from these (usually internal) electric forces.
So what do you gain by thinking about things this way? To my mind, very little: you're trading a relatively simple calculation - say the torque on a magnetic dipole in a magnetic field - for a very complicated one involving internal electric forces. This seems like a poor trade. Note that I am not arguing that "magnetic fields do no work" is not true. I am arguing that it is not useful. It's (relatively recent) overemphasis is not, in my mind, a good thing.
Thanks V50. I wish I could have put it so clearly.
Studiot
#34
Mar15-10, 01:06 PM
P: 5,462
Here is a challenge to those who say a magnetic field can do no work.
Design a non-magnetic system that will operate my solenoid door bell.
The requirements are that no part of the doorbell may be altered, except the magnetic generator may be removed if desired.
I maintain that there is no known force that can replace the magnetic coupling to transfer energy from the battery to the plunger.
Frame Dragger
#35
Mar15-10, 04:12 PM
P: 1,540
You could reverse the circuit so that the doorbell only goes off when the circuit is broken. In that case you could use a spring and maybe the Strong or Weak force. Granted, you'd need a particle accelerator in your doorknob, but I think that's quite fashionable.
Anyway, you could just design one out of clockwork. Press the plunger against a piezoelectric element which sparks a tiny gap firing the circuit... etc. Of course, you lose the solenoid...
... Oh wait, nothing can be altered except the removal of a system. How is that conducive to DESIGNING a system?
Studiot
#36
Mar15-10, 04:48 PM
P: 5,462
Since I have disassembled my solenoid in anticipation of a flood of non magnetic couplings and whilst I am waiting for all the geniuses (or genii?) here I am employing a man with a hammer. He told me his name was J Arthur Rank.
Seriously can you replace the magnetic coupling with some other sort of coupling?
The point is the solenoid transfers energy, magnetically to a mechanical striker and bell.
Register to reply
Related Discussions
Magnetic Fields and Work Classical Physics 74
Magnetic fields do no work? How come... Classical Physics 84
Magnetic fields do no work. Advanced Physics Homework 0
Do magnetic fields do work? Classical Physics 17
Why can't magnetic fields (that deflect electron beams) cant do any work to the beam? Introductory Physics Homework 6
