Thread Closed
Orders of convergence - how to prove that a sequence converges linearly/quadratically
Share Thread Thread Tools
Mar14-10, 08:17 AM   #1
Which of the following converge quadratically and which converge linearly?
a) 1/n^2
b) 1/2^(2n)
c) 1/sqrt(n)
d) 1/e^n
2. Relevant equations
All I've got in my lecture notes is: The sequence converges with order a if there exist constants a and C and integer N such that |x_(n+1) -x*| <= C|x_n -x*|^a, and n>=N.
3. The attempt at a solution
For a), I got the terms 1, 1/4, 1/9, etc, and concluded that it must converge linearly since I couldn't find a constant C such that x_(n+1) <= C(x_n). But I'm not sure if it's right, and I don't know how to explain it if it is right.
For b), I also had that it converges linearly, for the same reasons as above. Again, don't know how to explain it if it's right.
c) Same
d) Same
My answers seem really wrong because I don't think all of them converge linearly but I can't seem to find any constants C such that it works for quad convergence. I'm so confused..
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Mar14-10, 02:36 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
For (a), it's certainly true for all [itex]n[/itex] that
[tex]\left| \frac{1}{(n+1)^2} - 0 \right| \leq \left| \frac{1}{n^2} - 0 \right|[/tex]
(i.e., [itex]C = a = 1[/itex]) so this shows that the sequence converges (to zero) at least linearly.
If it were to converge quadratically, you would have to furnish a constant [itex]C[/itex] such that
[tex]\left| \frac{1}{(n+1)^2} \right| \leq C \left| \frac{1}{n^2} \right|^2[/tex]
for sufficiently large [itex]n[/itex].
But this is equivalent to
[tex]n^4 \leq C (n+1)^2[/tex]
so it's clear that no such [itex]C[/itex] exists, since the left hand side grows at a higher order than the right hand side. Therefore the sequence in (a) does NOT converge quadratically.
Try writing out in detail a similar argument for the other parts. If you can show me in detail what you have done for part (b) I'll try to help you find a suitable constant, if it exists, or to prove that one cannot exist.
Mar14-10, 04:55 PM   #3
Wow, your explanation made so much more sense than the one in the lecture notes. So they all converge linearly, since they are all decreasing sequences.
b) If it converges quadratically, then
Code:
[tex]\left|\frac{1}{2^{2(n+1)}}\right|\leq C\left|\frac{1}{2^{2n}}\right|^{2}[/tex]
Code:
[tex](2^{n})^{4}\leq C(2^{n+1})^{2}[/tex]
which won't work because the LHS grows at a higher order, like you said about the first one. So it converges linearly.
c) Quadratically:
Code:
[tex]
\left|\frac{1}{\sqrt{n+1}}\right|\leq C\left|\frac{1}{\sqrt{n}}\right|^{2}
[/tex]
Code:
[tex]
n \leq C\sqrt{n+1}
[/tex]
Again won't work because LHS grows at a higher order. So it converges linearly.
d) Quadratically:
Code:
[tex]
\left|\frac{1}{e^{n+1}}}\right|\leq C\left|\frac{1}{e^{n}}\right|^{2}
[/tex]
Code:
[tex]
(e^{n})^{2} \leq Ce^{n+1}
[/tex]
Same as previous.
Is that right? It seems a bit weird that my lecturer would give us four sequences that converge linearly...
Mar14-10, 06:21 PM   #4
Recognitions:
Quote by muso07 View Post
I agree it's a bit weird, but I believe your answers are correct.
Check out this Wikipedia page to see some examples of sequences that converge quadratically:
http://en.wikipedia.org/wiki/Rate_of_convergence
You need to have more rapid decay to achieve quadratic convergence, for example
[tex]\left\{\frac{1}{2^{2^n}}\right\}[/tex]
Mar14-10, 06:37 PM   #5
Cheers, that helped a lot. :)
Thread Closed
Thread Tools
Similar Threads for: Orders of convergence - how to prove that a sequence converges linearly/quadratically
Thread Forum Replies
prove sequence converges Calculus & Beyond Homework 7
Prove the sequence n/2^n converges to 0 Calculus & Beyond Homework 5
Prove the sequence converges uniformly Calculus & Beyond Homework 4
Prove that this sequence converges Calculus & Beyond Homework 16
how to prove a sequence converges linearly or quadractically? General Math 4
