Finding acceleration of a block being pushed up a ramp by a horizontal force
The problem involves a block being pushed up a frictionless incline by a horizontal force, with the goal of determining the block's acceleration. The context includes the effects of gravity and the geometry of the situation, particularly the angles involved.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the relationship between the applied force and the gravitational force components, exploring the geometry of right triangles formed by these vectors. There are attempts to calculate the components of the gravitational force and the applied force, with questions about the correctness of values and assumptions regarding the direction of motion.
The discussion is ongoing, with participants sharing their calculations and questioning the validity of their results. Some participants have identified potential errors in their calculations and are seeking clarification on the setup of the problem and the interpretation of the forces involved.
There is confusion regarding the direction of the net force and the motion of the block, with some participants questioning whether the block is indeed moving up the ramp or if it is simply being pushed up. The values used in calculations have also been debated, indicating a need for careful consideration of vector components.
cellfoneguy
A block is pushed up a frictionless incline by
an applied horizontal force as shown.
The acceleration of gravity is 9.8 m/s2 .
What is the magnitude of the resulting acceleration of the block?
Answer in units of m/s^2.
Sin(theta)=opposite/hypotenuse
Cos(theta)=adjacent/hypotenuse
Tan(theta)=opposite/adjacent
^^^^^^^^^above equations for a right triangle on a Free Body Diagram
F=ma
So if i extend the block's line and make a right triangle with that line and the line of the applied force, i know the theta of that triangle is equal to the ramp's, 34. I can also make a right triangle using gravity and its two vectors, one along the ramp and one perpendicular to the ramp. That triangle's theta is also 34. So to find the acceleration of the block, i need to subtract x from v (See attached picture). But i can't prove the two triangles are congruent, because the gravity vector triangle has only two known values while the force vector triangle has only 1. Help!
Wait, i got a little further on the problem.
Knowing that gravity is 9.8, i can find x and y of the gravity vector triangle.
x=sin(theta)g=~5.480090454
y=cos(theta)g=~8.124568211
SO now i know x.
I need to find v to get the net force, how?
The same principles that apply to one right triangle will apply to another. If you can relate mg to y, you can relate z to v.
ok i used the formula to calculate v and x. Then using f=ma, i found the acceleration. I was wrong.
I found a mistake, in that in the gravity vector triangle, i used 9.8 which is in m/s^2. After converting it to Newtons, i get that x is 20 something Newtons, which cannot be correct, because then the net force is negative, meaning the block is going down the ramp. However, the problem states the block is going up the ramp. whaaaaat?
Yes, given the values in the diagram, the net force is down the plane. Are you sure the problem stated that the block is moving up the plane? Or did it just say that it was being pushed up the plane (meaning that the push has a component up the plane)?
Well, i took x (11.18385807)-v (30.06090238) and got -18.87704431 N. Then i divided by 3.7 (the mass) and got 5.101903868, which is wrong. What?
Your values for x and v are incorrect.
i agree that the answer is a net force acting down the slope of the hll
are the correct values
13.746065934159120354149637745012 for x
and
5.4800904540133189355721957718627 for v?
  • · Replies 56 ·
