Improving Cosine Approximation Using Taylor Series in Matlab
The forum discussion focuses on creating a user-defined function in MATLAB to compute the cosine of an angle using the Taylor Series expansion. The implementation provided by the user initializes the term index 'n' at 2, leading to incorrect results due to the first term being added to 1, which skews the approximation. The correct approach is to start 'n' at 1 to ensure the first term accurately represents the cosine value. The estimated error is calculated using the formula E = |(Sn - Sn-1)/Sn-1|, and the loop continues until E is less than or equal to 0.000001.
  • Understanding of Taylor Series expansion
  • Familiarity with MATLAB programming
  • Knowledge of factorial calculations
  • Basic concepts of error estimation in numerical methods
  • Review MATLAB's built-in functions for trigonometric calculations
  • Learn about numerical stability in iterative algorithms
  • Explore advanced error analysis techniques in numerical methods
  • Investigate alternative series expansions for trigonometric functions
Mathematics students, MATLAB programmers, and anyone interested in numerical methods for approximating functions.
StaloyT
Write a user-defined function that determines cos(x) using Taylor Series expansion
Stop adding terms when estimated error, E<=.000001
sum Sn = Sn-1 + an
E = | (Sn - Sn-1)/Sn-1 |
function y = cosTaylor(x)
Sn=1;
Snm1=0;
n=2;
xr=x*pi/180;
E=1;
while E >= .000001
an=(-1)^n*xr^(2*n)/(factorial(2*n));
Snm1=Sn;
Sn=Snm1+an;
n=n+1;
E=abs((Sn-Snm1)/Snm1);
end
This gives values too large compared to what they should be.
I really don't understand why this doesn't work.
Any help is appreciated.
Thanks in advance!
Why did you start n as 2? It should be 1, since in your formula for an you use 2*n.
Starting with n = 2, your first term is added to 1, making the cosine greater than unity. The following terms have absolute values smaller than the first, so you will have always too large results.
