| Thread Closed |
Albert Einstein: High Functioning Autistic |
Share Thread |
| Apr2-10, 04:18 PM | #86 |
| Apr2-10, 06:01 PM | #87 |
Is that to say you agree, or that you hadn't read it, aren't able to read it (hence I started about the chaos) ? |
| Apr2-10, 06:33 PM | #88 |
I have argued a particular approach based on my familiarity with the neuroscience and psychological literature. People can take it or leave it. But the facts are out there and not terribly hard to find. |
| Apr2-10, 06:49 PM | #89 |
In fact, the article itself wasn't bad, it made no more conclusions that it was allowed to make from its data, in fact, it made little conclusions, it just outlined some experimental data and left readers to make up heir own mind. It's not a view, it's the result of some experiments, of which a lot are not scientific experiments / studies but rather 'remarkable documented cases.' Also, a thing you do indeed 'waltz over' though is my continued point that it needn't be so that what humans perceive as 'one thing' like eidetic memory or 'musical talent' is 'one thing' that has a single defined cause instead of multiple and different causes. These researches all assume it as 'common sense' or in fact implicitly assume it because it's just grounded in human naïve realism, but fail to prove it in the end. Once you assume explicitly the possibility that 'eidetic' memory can have a thousand different neurological causes the researches suddenly become quite quaestionable, same for autism, as the researches fail to prove themselves that in all cases of eidetic memory encountered, the neurology is the same. |
| Apr2-10, 07:04 PM | #90 |
However on the other hand, I am protesting about the collapsing of the category "autistic" and the category "extreme genius" based on some notion of a shared social awkwardness (which indeed is not a wise move, because, as I argue, social awkwardness does have "a thousand causes"). |
| Apr2-10, 07:44 PM | #91 |
| Apr2-10, 07:59 PM | #92 |
Well, Dirac comes across as the neurotypical one in this exchange.
| Apr3-10, 09:30 AM | #93 |
But as I illustrated above, apart from not being a category, the danger is also that by the power of suggestion people have a tendency to see things that are not there, symptoms one doesn't have simply because one has enough symptoms to 'have' autism on the neck, and then start seeing the rest too. Or in the case of that girl even worse, having no symptom at all. I still don't really understand why you called me 'rhetoric' though, if my vocabulary serves me rhetoric is being concerned with prose and elegant use of language to sway by praesentation rather than content, beforehand you accurately said that my posts are chaotic and badly structured, which is true, as I don't really put a lot of intention into how I phrase things and which words I use, making numerous 'stylistic errors' and having my sentences span the totality of paragraphs so I really don't see how one could find my posts to posses any 'rhetoric' |
| Thread Closed |
| Tags |
| autism, einstein, high functioning |
Similar discussions for: Albert Einstein: High Functioning Autistic
| Happy Birthday Albert Einstein! | General Discussion | 12 | ||
| Ten Obscure Factoids Concerning Albert Einstein | General Discussion | 19 | ||
| Others like Albert Einstein? | General Discussion | 3 | ||
| Relativity by Albert Einstein | General Physics | 9 | ||
| Einstein, Newton...autistic? | General Discussion | 1 | ||
