Worked out examples using Cauchy criterion for series
  • Thread starter Thread starter michonamona
    Cauchy Series
The discussion revolves around the Cauchy Criterion for series, specifically seeking worked examples to understand its application. The original poster expresses a need for demonstrations of the theorem as presented in their textbook, indicating that the problems are not for homework but for personal understanding.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss the method of grouping terms in series to apply the Cauchy Criterion, with one suggesting a comparison to another series. Questions arise regarding the meaning of grouping terms into powers of two.
The discussion is active, with participants providing insights and asking clarifying questions. There is an exploration of different interpretations of grouping terms, and some guidance is offered regarding the application of convergence tests.
Participants note that the original problems are not assigned homework, which may influence the nature of the discussion. There is also mention of a specific textbook and a reference link for further context.
michonamona
Hello everyone,
Can anybody suggest a website that has worked out examples using the Cauchy Criterion for Series? or, if your feeling ambitious, work out the following problems below:
1.
[tex]\sum^{\infty}_{n=1}1/n[/tex]
2.
[tex]\sum^{\infty}_{n=1}1/(n(n+1))[/tex]The reason why I'm asking for this is because our textbook introduces the theorem (Steven Lay) but it does not demonstrate its usage. I have also perused the web and was not able to find a complete demonstration.
I only need to see it being used. The problems above are not homework questions. I promise.
I appreciate your help
M
Check here for a review of the test and for reference to the variables I am referring to; http://en.wikipedia.org/wiki/Cauchy's_convergence_test.
Basically the trick is finding suitable values for m and n that make sure s_m - s_n can not be smaller than epsilon. This can be done in many ways but there's no systematic method. One way is to try to compare it to another series. The first example is a well known proof.
1 + 1/2 + (1/3 + 1/4) + (1/5 + 1/6 + 1/7 + 1/8) + (1/9 + ...+ 1/16) + (1/17+...+ 1/32) ... continually grouping them into groups of 2^n terms, you might want to investigate what each group must be larger than.
In terms of Cauchy, you are investigating [itex]s_{2^n} - s_{2^{n-1}}[/itex].
Thank you for your reply.
What do you mean by grouping them into 2^n groups?
Think he means groups of (1/2)^n terms
ie
1 + 1/2 + (1/4 + 1/4) + (1/8 + 1/8 + 1/8 + 1/8) + (1/16 + ...+ 1/16) + (1/32+...+ 1/32) ...
And note that s2n-1 = n+1 for the second sequence of partial sums
Then think about convergence tests you know
Being a fool I made it harder than it had to be! Simpler case to look at is m=2n.
  • · Replies 17 ·
