Volumes of Regular Icosahedron and Regular Tetrahedron
In summary, there is a question about whether a regular icosahedron can be made from 20 regular tetrahedrons and if their volumes would be equal. There is a formula for calculating the volume of a regular tetrahedron in terms of edge lengths, and when evaluated with all edge lengths equal to 1, the volume is 0.11785. However, there is some confusion about the actual volume of the icosahedron, as some sources suggest it is not exactly 20 times the volume of the tetrahedron. The person asking the question is interested in confirming their assumption and has built models to support it. They are seeking proof or disproof of this idea.
josdavi
Please teach me.
Is one Regular Icosahedron equal to twenty Regular Tetrahedrons ?
If the edgelength of both Regular Polyhedras is 1,
What would be their volumes ?
Can we prove (or disprove) the equation below ?
volume of Regular Icosahedron = 20 * volume of Regular Tetrahedron
Thank you.
Mathematics news on Phys.org
Originally posted by josdavi
Please teach me.
Thank you.
You've probably thought about this more than I have, and
now I have gotten interested. So maybe you could help.
the icosahedron has 20 faces, so it looks like it might be
made of 20 tetrahedrons fitted together (so your estimate
of volume would be right)
But I wanted to check this and I fetched a formula for
the vol of tetrahedron and when I calculated it out it said
0.11785
Is that right?
Something is eluding me about this, or I am doing something wrong. Here's a formul for tet volume in terms of edgelengths (on web from Berkeley prof Bill Kahan)
sqrt( 4u^2 v^2 w^2 – u^2 (v^2 +w^2 –U^2 )^2 – v^2 (w^2 +u^2 –V^2 )^2 – w^2 (u^2 +v^2 –W^2 )^2 +
+ (v^2 +w^2 –U^2 )(w^2 +u^2 –V^2 )(u^2 +v^2 –W^2 ) )/12 .
In the case you propose, all these edgelengths u,v,w,U,V,W
are equal to one. So it should be routine to get the volume
(sqrt(4 - 1 - 1 - 1 + 1))/12
sqrt 2 divided by 12
Damn, it comes out 0.11785 again!
I am having a hard time comprehending how the vol of the
icosahedron can be only 20 times the vol of the tet
if the tet vol is so small.
it certainly looks like the icos is made of 20 tets fitted together
because the icosahedron certainly has 20 faces
but we should check volumes just to make sure
and if I calculated right the tet volume is 0.11785
which would make the icosahedron volume 2.357
...(edit)...
And so 20 times the tet volume-----2.357-----is looking good.
Plus it is what one naturally visualizes because of the 20 faces.
WARNING (edited in later) I checked on google and was told that
the ratio of volume is not 20 but 18.51229586...
so I am confused about this. Have to go for now, but will
come back to it later.
Thank marcus.
I am not a mathematician, so I really need the teaching.
I had visited askgeeve.com a few days ago, this site gave me many
formulas of the volumes of Polyhedras, but I could not understand them. I am mostly interested to confirm my assumption -
A Regular Icosahedron can be made by 20 Regular Tetrahedrons.
I had made many pieces of regular tetrahedron & regular octahedron, when I put these pieces together, I found something interesting. We can make larger tetrahedron or octahedron with just the tetrahedron and octahedron units. For example -
Higher order Tetrahedron may be built by
t * Tetrahedron pieces + o * Octahedron pieces
Order 2 : t = 4, o = 1
Order 3 : t = 11, o = 4
Order 4 : t = 24, o = 10
Order 5 : t = 45, o = 20
etc.
Higher order Octahedron may be built by
Order 2 : t = 8, o = 6
Order 3 : t = 32, o = 19
etc.
I also put 20 tetrahedron pieces together and got a icosahedron shape,
but this model has some gaps, not the perfect regular one. I guess if
all of my prototypes of tetrahedron pieces are Regular (standard), I would get the Regular Icosahedron when 20 of them were connected together.
My assumption:
The volume of a regular Icosahedron is equal to
the volumes of 20 Regular Tetrahedrons.
Is there any proof or disproof of this before ?
My assumption:
I can't speak with any authority but was interested by the question. So let us look for confirmation and maybe someone
who has some expertise will step in and reply.
I am pretty sure the vol of tet is 0.11785
so that your estimate of isos is 2.357
Let us check that against somebody's calculation of the actual volume of the icosahedron. Is it actually 2.357 or not?
You said you asked jeeves and got volume formulas
so what volume formula for the icosahedron did you get?
It should be easy to evaluate and see if it is 2.357.
OUCH! I just looked on google and it said the
18.51229586!
http://euch3i.chem.emory.edu/proposal/www.teleport.com/~pdx4d/volumes.html
Josdavi and others,
this seemingly simple problem has me quite baffled
I think my figure for the tetrahedron volume must be wrong
although I calculated it using a formula posted by the
highly-esteemed Prof. Kahan
So all bets are off and moreover I have to be off for a few hours
and cannot clear this up!
Maybe someone else can step in and resolve this.
Be back later,
m
Well, we can compute the volume of a regular tetrahedron via the volume formula for any old pyramid:
The base would have vertices:
(0, 0, 0)
(1, 0, 0)
(1/2, sqrt(3)/2, 0)
Due to the symmetry, the apex would have to lie over the centroid at:
(1/2, sqrt(3)/6, x)
To have a unit edge length, x has to be sqrt(6)/3
The area of the base triangle is one half base height:
A = (1/2) * 1 * (sqrt(3) / 2) = sqrt(3) / 4
The volume of the pyramid is one third base height
(1/3) * (sqrt(3) / 4) * (sqrt(6) / 3) = sqrt(2) / 12 = .11785
This is certainly correct.
My hypothesis is that the 20 tetrahedra making the icosohedron are not regular; I can't see any clear reason why they should be in the first place. Regular tetrahedra packed together like to form hexagonal-like structures, but the icosahedron is pentagonal-like.
18.51229586.
Hello josdavi, hello Hurkyl,
I'm back---had to be away for the day.
Ahhh! Hurkyl has taken care of business here.
I think after my false starts earlier today
that probably that ratio 18.51 is right after all, so
since the tetrahedron volume is 0.11785
the icosahedron volume must be 18.51... times that, or
2.1817
Thank Hurkyl.
But if we pack five Regular Tetrahedron pieces together, surely we can get a Pentagonal-like structure. I do not know its formal name, therefore I just called it Simplex Star.
A Simplex Star formed by 5 regular tetrahedrons, has 7 vertices, 10 faces and 15 edges. Five of the faces have a common vertex, another five of the faces have another common vertex.
I have another question here:
Let s be the side length of the regular icosahedron and R the circumradius,
what is the relationship between s and R ?
Well...I think it's impossible to form an icosahedron with tetrahedrons because you cannot put tetrahedrons "around" a point to form a solidangle of 360...unlike triangles...which can be put this way and form a 360 plane-angle...
Thank bogdan.
Have you tried to glue 20 regular tetrahedron models to form the regular icosahedron shape ?
I did so, and it is definitely possible.
I found the relationship between s and R (of previous question) is
R = s
or
The circumdiameter of the regular icosahedron is two times of the edge length of the regular tetrahedron (or the regular icosahedron itself).
Would you please disprove this ?
Thank you.
Originally posted by bogdan
http://mathworld.wolfram.com/Icosahedron.html
that is an impressive webpage, thanks for posting the URL
It says the icos volume is (5/12)(3+sqrt(5))
which is the volume of 20 pyramids each with unit equilateral base and height of
(3sqrt(3) + sqrt(15))/12
and this height is called the "inradius", it is the distance from
the center out to the center of a face, or if you prefer it is the radius of an inscribed sphere.
Moreover the page gives an elegant discovery of the Greek mathematician Apollonius.
Apollonius found that the ratio of surface areas of Icosahedron and Dodecahedron is equal to the ratio of their volumes.
Or so this website appears to say. If true it is a new one to me.
I seem to recall that Archimedes discovered a similar fact about the sphere and its cylindrical envelope. The picture is of a tomato sitting inside a tin can just big enough to contain it. And the ratio of the surface areas (2/3) is the same as the ratio of volumes.
Apollonius of Perga was born around 261 BC---some 25 years after Archimedes----and dwelt in Alexandria.
Ok, short sketch of a proof that a regular icosahedron cannot be made up of regular tetrahedra:
First, consider a regular tetrahedron. In particular, consider the perpendicular bisector of one of its edges (it is a plane). The two opposite vertices of the tetrahedron lie in this plane (i.e. the two that aren't the endpoints of the edge in question). In this plane, one can find the angle the tetrahedron subtends; if A and B are the opposite vertices and M is the midpoint of the edge, then the measure of angle AMB is 70.53 degrees. (Which I computed from the coordinates I computed in a previous post)
Now, consider a regular icosahedron. The top 5 faces are five regular triangles meeting at a point. The outer edges of these triangles form a regular pentagon. Find coordinates for the vertices of the pentagon, and then the coordinates of the central point.
Now, select two of the adjacent triangles. If the regular icosahedron could be made of 20 regular tetrahedra, then these two adjacent triangles must be faces of one or more of those tetrahedra. Consider the perpendicular bisector of the edge joining these two triangles. Again, we know the coordinates of the opposite vertices and the midpoint, so we can compute the angle in this plane subtended by the icosahedron; it is 138.19 degrees.
Since 138.19 is not a multiple of 70.53, we cannot pack the tetrahedra into the icosahedron; one tetrahedron is not enough to form both of these triangles, and if we tried to use two tetrahedra, they'd overlap by about 3 degrees.
Thank Hurkyl again.
I just visited a website having many useful information.
http://www.intent.com/sg/polyhedra.html
There is a Table of Platonic And Archimedean Solids
(Updated: Wed, 26 Mar 2003.)
I got some values as below -
Platonic Icosahedron
total surface area (when edge length = 1) : 9.464101615
total surface area (when circumradius = 1): 9.464101615
Because their total surface areas are the same, I think they are (it is) the identical icosahedron, and it become clear that
A regular icosahedron is made of 20 regular tetrahedrons with the same edge length.
But I am still confused...
Does any expert know why their volumes are not in the ratio 1:20
(in the same table) ?
Volume (* in multiples of edge length cubed )
Regular tetrahedron: 0.117851130
Regular icosahedron: 2.181694991
I just sketched the outline of a proof that a regular icosahedron is NOT 20 regular tetrahedra put together.
Why would you think that it is?
Thank Hurkyl.
I have to tell you why I think a regular icosahedron is 20 regular tetrahedrons being put together. There is a long story, I sumarize it as short as possible.
(1). A regular Icosahedron has 20 faces that are equilateral triangles. A regular tetrahedron has 4 faces that are equilateral triangles.
(2). The circumradius of a regular Icosahedron is equal to the edge lenth of this regular Icosahedron itself. That means
Two adjacent vertices with the Circumcentre would make a equilateral triangle, and plus the third vertex (which is adjacent to the previous two) would form a regular tetrahedron.
(3). There are 20 equilateral triangle faces in total, and we can divide One regular icosahedron into 20 regular tetrahedrons.
I had made some paper models and some puzzle/block pieces to form different size/order platonic solids (except the dodecahedron) last year.
Please take a look at these links below.
http://www.geocities.com/dynamic_toys/josdavi_06.html
(Paper version)
http://www.twistymegasite.com/forum/viewMsg.asp?ID=1133
http://www.geocities.com/dynamic_toys/josdavi_07.html
(Magic Attractor version)
The images on those pages aren't loading for me.
Anyways, I see where your mistake lies; the figures you quoted are for the cuboctahedron, not the icosahedron.
Order 2 Icosahedron Puzzle
I forgot to indicate that
if we put 12 Simplex Stars onto the 12 concaved parts of the Ball-Shaped object formed by 20 octahedrons connected together, then
it will become a larger (order 2) Regular Icosahedron. we can obviously see the larger Regular Icosahedron is formed by 20 larger (order 2) Regular Tetrahedrons. Each of the larger (order 2) Regular Tetrahedrons is made of 1 regular octahedron + 4 regular tetrahedrons (smaller ones).
The pictures of the Ball-Shaped object (Helio-Solid) and the Simplex Star I mentioned may viewed in the pages below.
(Paper version)
1. What is a regular icosahedron?
A regular icosahedron is a three-dimensional shape with 20 identical equilateral triangular faces, 30 edges, and 12 vertices. It is a type of polyhedron, which is a solid shape with flat faces, and is one of the five Platonic solids.
2. How do you calculate the volume of a regular icosahedron?
The formula for calculating the volume of a regular icosahedron is V = (5/12) * √3 * a³, where "a" represents the length of one edge. This formula can also be written as V = (5/12) * √5 * (3 + √5) * a³.
3. What is the relationship between a regular icosahedron and a regular tetrahedron?
A regular icosahedron and a regular tetrahedron are both types of Platonic solids. The regular icosahedron has 20 faces, while the regular tetrahedron has 4 faces. However, both shapes have equilateral triangular faces and are made up of identical regular polygons.
4. How do you find the volume of a regular tetrahedron?
The formula for calculating the volume of a regular tetrahedron is V = (√2/12) * a³, where "a" represents the length of one edge. This formula can also be written as V = (√2/12) * (2√3 * a³).
5. Can the volume of a regular icosahedron or regular tetrahedron be calculated using other methods?
Yes, the volume of a regular icosahedron and regular tetrahedron can also be calculated using trigonometric functions. For a regular icosahedron, the volume can be found using the formula V = (√3/2) * a³ * (3 + √5) * cot(π/5). For a regular tetrahedron, the volume can be calculated using the formula V = (√2/12) * a³ * (1 + 4 * cot(π/6)).
  • General Math
  • General Math
  • General Math
