How Do the Gauges of 1PN and Schwarzschild Metrics Differ?
  • Context: Graduate
  • Thread starter Thread starter andert
    Metric Schwarzchild
The discussion focuses on the differences between the gauges of the 1PN (Post-Newtonian) metric and the Schwarzschild metric in General Relativity. The 1PN metric's time-time component is expressed as g_{00} = -1 + 2U - 2U^2, where U is the Newtonian potential, while the Schwarzschild metric's time-time component is g_{00} = -1 + 2M/r. The absence of a quadratic term in the Schwarzschild metric is attributed to its exact solution of the field equations, highlighting the role of gauge choice in defining metrics. The 1PN gauge is identified as harmonic, allowing for specific coordinate transformations that can eliminate certain terms in the metric.
  • Understanding of General Relativity and metric tensors
  • Familiarity with Post-Newtonian approximations
  • Knowledge of gravitational potential and its role in metric components
  • Concept of gauge invariance in physics
  • Study the implications of gauge choice in General Relativity metrics
  • Explore the derivation and applications of the 1PN metric
  • Investigate the Schwarzschild solution and its significance in astrophysics
  • Learn about harmonic coordinates and their use in gravitational theories
Researchers in theoretical physics, particularly those focused on General Relativity, cosmologists studying gravitational fields, and students of advanced physics looking to deepen their understanding of metric differences in gravitational theories.
andert
I'm sure there is a simple answer to this question, but I have been looking at the first Post-Newtonian (1PN) metric (for my own research) and noticed that the time-time component of the GR metric is:
[tex]g_{00} = -1 + 2U - 2 U^2[/tex]
where U is the Newtonian potential.
The time-time component of the Schwarzschild metric, however, is
[tex]g_{00} = -1 + 2M/r[/tex].
There is no quadratic in the Newtonian potential even though this metric is an exact solution of the field equations. Is this because it is in a different gauge?
You can make g00 look like anything you like, just by a choice of coordinates. Suppose I set g00=f(r), where f is some arbitrary function, and I don't give you any other information about my coordinates. You can then use this equation to define an r coordinate. For instance, suppose g00 changes by a factor of 2 between r1 and r2. Then we've effectively defined r=r2 to be the location where gravitational time dilation differs by a factor of 2 from its value at r=r1. With this implicit definition of the r coordinate, we can now go ahead and infer the rest of the metric.
Alright, yes, coordinate system or gauge. I see that. Each of them is a in a specific gauge. Now, what is different about the gauges of the 1PN and Schwarzschild metrics specifically? The 1PN gauge is a harmonic one. So if I were to take a static spherically symmetric field, I would have the 1PN time-time component,
[tex]g_{00} = -1 + 2M/r - 2(M/r)^2[/tex]
Is the idea that, in this special case, we can make a change of gauge (coordinates) to eliminate the quadratic term but in the general case of many bodies (with a sum over masses) we cannot?
  • · Replies 37 ·
  • · Replies 19 ·
  • · Replies 18 ·
