Energy of a deuteron
by danielatha4
Tags: deuteron, energy
danielatha4
danielatha4 is offline
#1
Mar18-10, 03:49 PM
P: 113
A proton (1.672610-27 kg) and a neutron (1.674910-27 kg) at rest combine to form a deuteron, the nucleus of deuterium or "heavy hydrogen". In this process, a gamma ray (high-energy photon) is emitted, and its energy is measured to be 2.39 MeV (2.39106 eV). Keeping all five significant figures, what is the mass of the deuteron? (Assume you can neglect the small kinetic energy of the recoiling deuteron.)
2. Relevant equations
Rest Energy = m c^2
Ebefore=Eafter
3. The attempt at a solution
I found the energy before the combining by
c^2 (1.672610-27+1.674910-27) = 3.0086*10^-10 J
this should equal the energy of the deuteron (mc^2) + the energy of the photon
energy of the photon in joules: 3.8292*10^-13 J
therefore:
3.0086*10^-10 = mdc^2 + 3.8292*10^-13
md=3.3433*10^-27 kg
However, this isn't right
Phys.Org News Partner Science news on Phys.org
Cougars' diverse diet helped them survive the Pleistocene mass extinction
Cyber risks can cause disruption on scale of 2008 crisis, study says
Mantis shrimp stronger than airplanes
Mindscrape
Mindscrape is offline
#2
Mar18-10, 06:33 PM
P: 1,877
Do you know the correct answer? You should be right, unless there is a rounding error, but I know that the mass of deuteron is just about what you've stated. Make sure you're giving the answer in the correct units (usually we talk about particle masses in terms of rest mass and give the units in MeV).
E.T.
E.T. is offline
#3
Mar19-10, 11:45 PM
P: 4
Quote Quote by danielatha4 View Post
therefore:
md=3.3433*10^-27 kg
you're right, it's wrong- binding energy is negative so the above equation should read:
3.0086*10^-10 = mdc^2 - 3.8292*10^-13,
so
md=3.34318*10^-27 kg
only a fraction out.
What gets me is that, where Ed is the deuteron binding in joules, Up and Un are the proton and neutron magnetions respectivey and Uo is the magnetic permeability of free space:
(UpUnUo/Ed)^1/3 = 0.746 fm
in other words a coupling distance between proton and neutron forming a deuteron of about half a nuclear radius from simple magnetic dipole binding, without having to invoke an extra-nucleonic strong force at all. Protons will also bind nicely once the magnetic attraction overcomes electrostatic repulsion at about 1.8 fm, at an energy of about 532Kev. Of course there are no quantum numbers involved here so the digits are subject to change, but not the scale, which is one of nuclear interactions.
vela
vela is offline
#4
Mar20-10, 04:50 AM
Emeritus
Sci Advisor
HW Helper
Thanks
PF Gold
P: 11,530
Quote Quote by E.T. View Post
so
Actually, you have it backwards.
E.T.
E.T. is offline
#5
Mar20-10, 06:00 PM
P: 4
http://hyperphysics.phy-astr.gsu.edu...ne/nucbin.html..
Ep=En (roughly)
so (2x931 Mev - 2.39 Mev)/(Nqc^2). About 0.3% Less than the sum of the individual nucleons was the point :)
mrrm17
mrrm17 is offline
#6
Mar29-11, 04:06 PM
P: 1
I know what you happened. You got all the steps right, but you probably need to use the speed of light as 3*10^9 in the program. I did this same problem for my class and i figured it out by your post since it didn't except my answer wither until i did that.
E.T.
E.T. is offline
#7
Jul1-11, 12:38 PM
P: 4
although i now realise the formula is wrong by a factor of 4pi, and the separation distance is also wrong- I have been looking at Yukawa potentials, but formalism constantly gets in the way of a formula which is actually useul when it comes to replicating numbers on a calculator. It's nice to know people are out there to help and don't just ignore wrongheaded ideas in favour of stating the equally incorrect (for example that the deuteron is heavier than its constituents), or repeating indeciperable jargon. :| Einstein would be ashamed!
Register to reply
Related Discussions
Deuteron Wavefunction Question Advanced Physics Homework 1
calculate that the proton and neutron in a deuteron High Energy, Nuclear, Particle Physics 3
Dissociation of deuteron by gamma rays Advanced Physics Homework 4
Binding Energy of the Deuteron High Energy, Nuclear, Particle Physics 2
