The Effects of Distance and Mass on the Casimir Force
  • Context: Graduate
  • Thread starter Thread starter r637h
    Casimir effect
The discussion centers on the Casimir Force, specifically examining the effects of distance and mass on this quantum phenomenon. Participants explore the relationship between gravitational attraction and the Casimir Force, questioning whether gravitational effects are significant in this context.
  • Rudi questions whether gravitational attraction between the masses of the plates affects the Casimir Force and whether other forces are factored out.
  • eNtRopY asserts that the Casimir Force is not influenced by gravitational or electrostatic attraction, describing it as a quantum effect related to virtual photon pressure.
  • Creator provides a more detailed explanation of the Casimir Force, correcting Rudi's formula and discussing the significance of vacuum energy density between plates. They suggest that gravitational attraction is likely negligible but propose a calculation to compare gravitational and Casimir forces.
  • Rudi expresses gratitude for the clarification and acknowledges the potential insignificance of gravitational effects, while also noting the relevance of the Casimir effect in microtechnology applications.
Participants do not reach a consensus on the significance of gravitational attraction in relation to the Casimir Force. There are competing views on the relevance of gravitational effects, with some suggesting it is negligible while others propose calculations to explore the relationship further.
There is uncertainty regarding the assumptions made about the gravitational force's impact on the Casimir Force, as well as the conditions under which these forces may be comparable. The discussion also highlights the need for further experimental validation.
r637h
This is a simple (and possibly not very bright) question:
We know that F=A/d^4 for the Casimir Force (~10^-7 N for two cm^2 plates).
Does the gravitational attraction between the masses of the plates not figure?
I once thought that this was not an EM effect as such or at least doesn't depend on EM waves passing 'through' between the plates. Is that right?
Are various other possible forces factored out, or simply just don't apply?
I should know the answer, but for now, I'm stumped.
Thanks, Rudi
The Casimir Force is dependent on neither graviational nor electrostatic attraction. From what I vaguely remember, it is a quantum effect that can be thought of as being due to a difference in virtual photon pressure.
eNtRopY
Does the gravitational attraction between the masses of the plates not figure?...
Rudi
Interesting question, Rudi.
Casimir predicted (according to QED) a reduced vacuum energy density between two closely spaced plates (due to truncating of virtual photon modes)which results in an attractive force. That force increases (by the inverse 4th power) as the distance d, between the plates decreases. You formula is not exactly correct. The correct formula is:
F = [pi]hcA/(480 d^4)
h=Planck's; A = area of plates; c= speed of light; d = distance between plates.
To answer your question. Usually any measurement is done with flat neutral plates to null electrostatic force; (the distance must be very small to get a Casimir force that is measureable.) However, I've never seen any calculation done to accommodate adjustments due to gravitational attraction, which I assume would be too small to matter. How...ever, just to make sure, try using small plate mass (say, somewhere between 10 to 50 grams) and 1 cm^2 to calculate grav.F using Newtonian eqn. Depending on the plate thickness, R (distance between the center of plate thickness) could be about maybe .5 to 6 mm. (F=Gmm/R^2)
Then compare that grav. F value with the Casimir Force (using the formula above) OR: set the 2 eqns. equal to one another to see at what plate separation the Casimir force would be comparable to mutual gravitational attraction, (see below.) It may be interesting.
Creator
Gmm/R^2 = [pi]hcA/480 d^4
solving for d and assuming d<<R:
d = 4th root[[pi](R^2)hcA/480 Gm^2]
However then you will need to determine if, at that separation, the force will be great enough to be measureable.
To Creator:
Many Thanks: I didn't realize that the simple equation, which I have seen cited, wasn't correct. Your equation makes a lot more sense, explaining the EM phenomenon relationship.
In particular, thanks for the gravity measure suggestion. (If I don't find it in the literature; we have Igor and Spook, down in the basement, who'll gladly do the experiment for an extra ration of gruel or swill.*) If anything significant is found, I'll let you know.
As you suggest, it may be considered insignificant on paper.
Of course, Casimir effect has gained new prominence lately: Applications in Microtechnology.
*( Sorry, weak attempt at humor.)
Again Many Thanks, Rudi.
  • · Replies 21 ·
  • · Replies 46 ·
  • · Replies 46 ·
  • · Replies 17 ·
  • · Replies 16 ·
