Heat Dissipated By a Freezer's Condensing Unit
  • Thread starter Thread starter vta10
    Heat Unit
The discussion focuses on the heat dissipation of a freezer's condensing unit and explores methods to utilize this heat effectively. Suggestions include rejecting heat outdoors to reduce indoor heating and combining the freezer's heat pump with a water heater for improved efficiency. However, participants caution that adding devices to harness this heat may reduce the freezer's overall efficiency. Maintaining clean cooling coils and using efficient heat sinks, such as cool water from natural sources, are recommended strategies for optimizing performance.
  • Understanding of thermodynamics related to heat transfer
  • Familiarity with refrigeration cycle principles
  • Knowledge of heat pump systems
  • Experience with energy efficiency optimization techniques
  • Research methods for quantifying heat dissipation from condensing units
  • Explore the integration of heat pumps with water heating systems
  • Investigate the impact of cooling coil maintenance on refrigeration efficiency
  • Learn about efficient heat sink options for industrial refrigeration systems
Refrigeration engineers, HVAC technicians, energy efficiency consultants, and anyone involved in optimizing freezer performance and heat recovery systems.
vta10
I am trying to come up with a way to utilize the heat that is being dissipated by a huge freezer's condensing unit. Currently the heat is being dumped permanently in the plenum.
One of the possibilities that a leaning for the most is using the heat that is being dissipated during the heating days and exhaust it during the cooling days.
Any suggestions on how to quantify the heat that is being dissipated by the condenser unit?
I'm not sure that there is much to be gained from here. If you add any sort of device that adds thermal resistance to the unit such as a heat engine which runs off the heat from the condenser you will reduce the efficiency of the freezer. Adding something to the cooling unit will increase the temperature of the unit (assuming the same throughput of heat) reducing the efficiency of the system.
As for rejecting the heat to outdoors to reduce indoor heating (or reduce air conditioning load) will see a similar decrease in the freezer efficiency. Theoretically you could combine the heat pump from the freezer to your water heater which could potentially improve the efficiency of the whole system combined but it just isn't really worth it.
A better method for increasing efficiency of a freezer is to simply keep the cooling coils dust free so they dissipate the heat with less work. Using a better heat sink such as cool water from a swimming pool, lake or river are more efficient then rejecting heat to hotter sinks such as air on a warm day.
  • · Replies 28 ·
