Red blood cell production time
by lisab
Tags: blood, cell, production, time
lisab
lisab is offline
#1
Mar20-10, 12:22 PM
Mentor
lisab's Avatar
P: 2,917
If a person loses enough blood to become moderately anemic, how long does it take for the red blood cell count to return to normal? I mean roughly...would it be on the order of days, weeks, or...?
Is daily iron intake a typical limiting factor in this process?
Phys.Org News Partner Medical research news on Phys.org
Pregnancy complications may be more common in immigrants from certain regions
Use of frozen material for fecal transplant successfully treats C. difficile infection
Death rates from pancreatic cancer predicted to rise in Europe in 2014
zomgwtf
zomgwtf is offline
#2
Mar20-10, 12:59 PM
P: 501
Quote Quote by lisab View Post
The second question third paragraph.
http://www.runnersweb.com/running/rw...dDonation.html
Now this is only a 'rough estimate' for only 450mL of blood loss. Losing more or less blood will obviously effect the recovery time and also the rate of regeneration. Blood is on a positive feedback so lower oxygen being sent to the body will cause more blood cells to be created etc. (AFAIK)
I'm not exactly sure about the iron question but I'll take a stab at it.
Iron's function in the blood specifically has to do with the hemeoglobin. So the blood will still be created but you will still remain anemic because your blood can not properly transfer oxygen. It is important to keep your iron intake up to ensure that this doesn't occur.
digitalsurg
digitalsurg is offline
#3
Mar20-10, 03:20 PM
P: 4
120 days it takes to mature a RBCs but there are things that can push that envelope forward.
Andy Resnick
Andy Resnick is offline
#4
Mar20-10, 03:23 PM
Sci Advisor
P: 5,468
Production of erythrocytes takes about 4 days, and is stimulated by hypoxia, not iron intake:
http://faculty.ucc.edu/biology-potte...rythrocyte.htm
The physiological 'iron cycle' is not that well understood:
http://www.ncbi.nlm.nih.gov/pubmed/17014365
http://bmb.oxfordjournals.org/cgi/pdf_extract/37/1/25
http://scienceweek.com/2005/sb050218-4.htm
digitalsurg
#5
Mar20-10, 03:48 PM
P: 4
that statement is factually not correct but I do think they are talking not of erythropoesis , which is 100-120 days............they are referring to recruitment from the marrow of mature RBC's which is about 4 days. The cells develop in the bone marrow and circulate for about 100120 days in the body before their components are recycled by macrophages.
The total turnover for anemia is what matter most. And it can be shortened with meds and other methods we surgeons use.
zomgwtf
zomgwtf is offline
#6
Mar20-10, 08:47 PM
P: 501
Quote Quote by digitalsurg View Post
that statement is factually not correct but I do think they are talking not of erythropoesis , which is 100-120 days............they are referring to recruitment from the marrow of mature RBC's which is about 4 days. The cells develop in the bone marrow and circulate for about 100–120 days in the body before their components are recycled by macrophages.
Err, well erythropoiesis takes around 7 days to complete. They are released from the bone marrow as reticulocytes and it takes around 2 of those days for it to mature into erythrocytes.
The life-cycle of the erythrocyte is generally accepted as 100-120 days. At which point the get sorta 'eaten' up mostly by the spleen.
This is only part of the problem though because you lose a lot more than just erythrocytes when you bleed out... they all will get regenerated but erythrocytes is only part of the problem.
EDIT: As well I noticed a mistake I made in my first post, I said positive feedback, it should be negative feedback. I explained it correctly just used the wrong feedback term . As well it is for the most part controlled by the kidney, which regulates the production of blood cells based on how much oxygen it is receiving. So if you lose blood it will receive less oxygen therefore increasing the amount of blood cells being produced.
AyazM
AyazM is offline
#7
Mar22-10, 04:48 AM
P: 42
Yes, when you lose blood you definitely lose your iron as well. In that case, iron deficiency in diet would limit recovery and you'd get a clinical picture of microcytic hypochromic anaemia. That's similar to occult losses of blood, such as from the Gastrointestinal tract that typically cause iron deficiency anaemia. On the other hand, with a case of haemochromatosis, you'd see a typical picture of normocytic normochromic anaemia.
Timeline for recovery is already stated in above posts.
Register to reply
Related Discussions
Physics behind blood vessel constriction and blood pressure? General Physics 6
Calculating conductivity of the cell interior and the blood Introductory Physics Homework 1
What to eat to aid in red blood cell reproduction? Biology 6
red blood cell general concepts. Biology 3
