| Thread Closed |
Psi/Consciousness studies alluding to downwards causality |
Share Thread |
| Mar21-10, 08:55 AM | #1 |
I've been doing a lot of reading on Psi-phenomena experiments as of late, and it appears as though an overwhelming number of experiments are producing statistically compelling positive results (although, these are small results that are produced over long period of time). I find this amazing as if proven this will be a discovery that will change almost all of science. Obviously, I can't wait to see what the next 30 years of attempted replication will bring.
Discuss: What more is needed for conclusive proof. If this phenomenon is conclusively proven, what are the subsequent consequences. Some sources: - http://dbem.ws/online_pubs.html (Scroll down to "Psi phenomena (ESP)" for his papers) - http://noosphere.princeton.edu/ (The most compelling, the most bulletproof to skeptical criticisms, click on "main results" up the top left) - http://www.princeton.edu/~pear/ (Go to publications and read the papers) Criticism (actually by Apeiron, PF member): http://dichotomistic.com/mind_readin...ear%20lab.html EDIT: Some graphs to get you guys reading: (PEAR proposition 1995 paper) ![]() ![]() (Princeton PEAR 1992 paper on human/machine interaction) ![]() ![]() ![]() (noosphere.princeton.edu experiment)
| Mar21-10, 09:11 AM | #2 |
Mentor
I've never seen a study I considered all that compelling and I'm not going to read through the dozens you posted: could you point to one good one that had a good experimental setup and produced consistent, statistically significant positive results?
| Mar21-10, 09:17 AM | #3 |
The PEAR papers are also really good.. |
| Mar21-10, 10:21 AM | #4 |
Double post, sorry.
| Mar22-10, 03:13 AM | #5 |
This is really weird, especially theory and speculations part in the princeton link.
| Mar22-10, 03:28 AM | #6 |
This is either one of the most groundbreaking discoveries of our lifetime, or a spectacular failure of experimental design, or a spectacular misuse of statistics. Truly exciting.
| Mar22-10, 01:35 PM | #7 |
If an author can't get a paper published in the mainstream, why should we give it any weight at all? |
| Mar22-10, 03:20 PM | #8 |
The mainstream isn't the holy Grail. I'm kind of curious what the problem with downward causation is.
I'm uncomfortable with it too, but the general tenant is that the system affects the components. Would it really be surprising that global constraints in a system effect the outcome of the individual elements of the system? Also, we've never seemed to have mentioned upward causation before downward causation was mentioned. Why do we suddenly assume upward causation is the only type of causation once somebody mentions downward causation? We never cared before. I'm also confused about the significance of the heirarchy. If the heirarchy can be described subjectively, then we could construct models in either direction depending on our interest. |
| Mar22-10, 03:53 PM | #9 |
Even Newton's third law recognised downward causality - for every (ie: locally constructive) action, there is an equal and opposite (ie: equilbrium) reaction (ie: global constraint). Though Newton's simplification of course was to reduce the global scale constraint to a locally opposed force vector. But that is just a modelling convenience, not an ontic truth. Had to mention that again Pythagorean as there is a sequence of ideas here. Complementary or synergistic causality is where it all starts to come into focus in the systems perspective. |
| Mar22-10, 04:01 PM | #10 |
| Mar22-10, 04:02 PM | #11 |
If you don't find the signal you want averaging over say five minute intervals, then something may pop out over 3 or 15. But its been a few years since I read the literature or talked with those involved. So the REG analysis may have been standardised to fix this criticism. |
| Mar22-10, 04:04 PM | #12 |
| Mar22-10, 05:02 PM | #13 |
I can tell you Radin did agree that data-mining was a valid possible criticism. He also defended himself against it, but I wasn't too convinced. But for those who find googling a chore, here are a few links it took seconds to find. http://www.lfr.org/LFR/csl/library/Sep1101.pdf http://noosphere.princeton.edu/papers/jseScargle.pdf http://www.thenational.ae/article/20...1/1036/OPINION http://www.skepticnews.com/2005/04/terry_schiavo_a.html http://skepticreport.com/sr/?p=560 http://www.skeptiko.com/74-radin-nel...consciousness/ http://www.theage.com.au/news/in-dep...459869857.html http://www.manticeye.com/article.php?id=1061_0_3_0_C |
| Mar22-10, 05:23 PM | #14 |
There's also the more obvious example of air molecules confined in a balloon. If we take the volume of the system (the balloons boundares) to be at the top, it is causally affecting the air molecules. But we can also look at the molecules of the balloon membraine to avoid mentionig downward causation. However, wouldn't occams razor cut the latter out as the more complicated explaination, leaving us with downward causation? |
| Mar22-10, 05:46 PM | #15 |
But downward causation is really to do with Aristotle's four causes analysis of causation. So that would be the reason why returning to material cause (talking about the rubber) would be missing the point. At the global scale, we would be seeking the formal causes (the formal and the teleological in Aristotle's scheme). So the questions become who constructed the balloon, for what purpose, and what is the general form by which that construction exerts its downward constraint? |
| Mar23-10, 03:08 PM | #16 |
| Mar23-10, 03:12 PM | #17 |
It sounds like you two may want to start another thread in philosophy.
This is the question that must be addressed: Were any of the PEAR papers published in mainstream journals - not to include the journal of the National Institute for Discovery Science, which is not a proper source? The journal must be subject-appropriate, and listed here http://scientific.thomson.com/index.html |
| Thread Closed |
Similar discussions for: Psi/Consciousness studies alluding to downwards causality
| Near Death Studies - Consciousness After Death | General Discussion | 87 | ||
| graduate studies and postgraduates studies | Academic Guidance | 2 | ||
| Causality in QM | General Discussion | 11 | ||
| p-consciousness, a-consciousness, and reflexes | General Discussion | 2 | ||
| Consciousness Studies: Misdirected and Conclusions Fated? | General Discussion | 19 | ||
