Friction Coefficient for Brake Pads: Validity of F=2x(UN) Equation?
The discussion centers on the validity of the equation F=2x(UN) for calculating the friction coefficient of brake pads. The user tests the friction by pulling a brake disc between two clamped brake pads, measuring the maximum force required for slipping. The consensus is that while both equations F=UxN and F=2x(UN) are referenced, the latter is applicable when both brake pads exert identical forces and coefficients of friction. The scenario changes if one pad is frictionless, leading to F=1x(UN) for the functional pad.
  • Understanding of basic physics principles, particularly friction.
  • Familiarity with the concepts of normal force (N) and friction coefficient (U).
  • Experience with load cell measurement techniques.
  • Knowledge of brake system mechanics and their operational principles.
  • Research the derivation and applications of the friction equation F=UxN.
  • Explore the impact of varying normal forces on friction coefficients in brake systems.
  • Investigate load cell calibration methods for accurate force measurements.
  • Study the effects of different materials on friction coefficients in braking applications.
Mechanical engineers, automotive technicians, and researchers focused on brake system design and performance optimization.
protector
I've been trying to figure out the friction coefficient of some brake pads. My test fixture only allows me to pull (F2) a brake disc between two brake pads clamped around the disc with a force F1. I then measure with a load cell the maximum force required for the brake disc to slip.
My question is simply, will the basic equation F=UxN be valid, or is it correct to assume that F= 2x(UN) in this scenario assuming F1 and U is identical for both brake pads?
I've been googling the topic and my impression is that both equations are used.
Should be F=2 x (UN). Imagine replacing one of the pads with a frictionless pad and then you'd get F = 1 x (UN) for the one pad with friction.
12K
  • · Replies 17 ·
10K
