Thread Closed
How do free electrons impact reflectivity
Share Thread
Mar22-10, 07:39 AM   #1
How do free electrons (metals) impact reflectivity. Why are they more reflective than another surface without free electrons (valence).
Does this mean that a medium with no valence electrons will be 100% non reflective.
Thanks
PhysOrg.com physics news on PhysOrg.com
>> Novel synthesis technique for high efficiency conversion of source gas to diamond
>> Scientists capture crystallization of materials in nanoseconds
>> Discovery of new material state counterintuitive to laws of physics
Mar28-10, 11:17 AM   #2
Anyone?
Mar29-10, 02:49 AM   #3
Recognitions:
Well, free electrons will shield any electric field (faradays cage) so that the electric field has to vanish at the surface of a conductor. This is only possible for a 50:50 superposition of forward and backward travelling waves which corresponds to (almost) perfect reflectivity.
In general, any deviation of the refractive index from its vacuum value 1 will also lead to reflectivity, so free electrons are not necessary for reflection.
Furthermore, the reflectivity depends on the angle of incidence. So any material becomes a nearly 100% reflector for almost 90 degree angle of incidence.
Mar29-10, 06:15 AM   #4
Well.. I was looking for reflectivity for radiation, not the static case.
I think it has something to do with "free" electron can match the incomming radiation pretty much 100% up to the plasma frequency which is derivable via drude model. Above this, a metals reflectivity of radiation starts to fall off
For the case with No free electrons, I'm assuming that the atomic bonds (through dampening) prevent frequency matching , so reflectivity and absorption only occur for resonant frequencies.
Mar29-10, 08:02 AM   #5
Recognitions:
I did not refer to the static case either. The absolute value of the dielectric constant of a metal is quite large for frequencies well below the plasma frequencies (it falls approximately off from its static value with an inverse power of frequency) so that the electric fields inside the metal (and at the surface) is generally small, which is sufficient to explain the high reflectivity.
While it is true that absorption occurs only for resonant frequencies, this is not true for reflectivity. Reflectivity depends on both the real and the imaginary part of the index of refraction, while absorption depends only on the imaginary part. However, although the real and imaginary part of the index of refraction are related by a Kramers Kronig relation, the latter is non-local in frequency space so that the index of refraction can deviate considerably from its vacuum value for frequencies far off resonance.
Jun9-10, 04:44 AM   #6
I think in case of metals where we have free electrons available for conduction, when EM radiations fall on the surface of metals, electrons very close to Fermi surface vibrate thus and in this process they emit radiations. This why metals have high absorption and reflectivity and low transmission. That is to say at particular frequency, which might be their optical band gap, transmission falls steeply before and after that.
Jun27-10, 04:21 AM   #7
Materials having free electron are good reflectors because the free electron can oscillate under the influence of the incident light's electric field. The oscillating electrons then re-emit those radiations with the same frequency. This is the reason for their high reflectivity.
The re-emitted light is scattered in 2Pi direction. If the surface is smooth, these reflected wavefronts interfere constructively along the direction of reflection (according to laws of reflection). If the surface is rough, the addition is not coherent and the reflection is diffuse.
For material with bandgap greater than the energy of the incident photon, light gets transmitted and the material will appear to be transparent is there are no absorbing centers (defects etc.).
Metals do not have optical band gaps.
Jun27-10, 04:33 AM   #8
Metals do not have optical band gaps.[/QUOTE]
i think metals do have optical gaps which should not be confused with semiconducting gap however they might be very narrow. e.g. in rare earth metals 4f core electrons do not take part in conduction or bonding but they are active to make optical transistions.
Jun27-10, 04:47 AM   #9
I am not sure if we can call them band gaps. Those are essentially atomic levels.
Jun27-10, 04:52 AM   #10
absolutely, atomic/molecular orbitals are fundamentally same thing, probably that is why distinction is made by writing "optical" or "semiconducting" .
Jun27-10, 11:13 AM   #11
Recognitions:
Yes, e.g. the red colour of copper is due to interband transitions from the d-band to the conduction band. This is a true absorption phenomenon, in contrast to reflectivity in case of an " ideal " metal. An ideal metal is non-absorptive as it reflects all the intensity. In the case of copper or gold this has a strange consequence, i.e. the reflectivity of copper or gold is lower in regions where the metal is absorbing and transmittion increases there. This can be seen in some light bulbs which are covered with a thin sheet of copper or gold. The light which passes trough the metal is of greenish colour. Thatīs where absorption is highest.
Jun27-10, 11:29 AM   #12
Ya correct. However, the definition of "ideal metal" can be different in different contexts. Like Cu can be an ideal metal while discussing conductivity.
Agreed with the discussions above.
But I think there is no difference between the "semiconducting" and "optical" band gap. I am saying this because again I do not think that the atomic levels and bands are the same thing. The rules and absorption processes are different for the case of continuum absorption and discrete absorption. The absorption spectra are completely different in both cases. Lots of concepts that hold for the case of atomic levels lose their meaning for bands.
Jun27-10, 07:28 PM   #13
Quote by abhi2005singh View Post
I would like to know what concepts you are refering to. i have encountered such materials which do posses band gaps (optical) but their temperature vs resistivity plots clearly show that these are not semiconducting gaps. however one can speculate that there are defects or heavy doping. none-the-less i guess i dont have any confusion about this but happy to discuss it further.
Jun27-10, 11:58 PM   #14
I was referring to the properties like the angular momentum quantum numbers. Even the idea that a particular state is due to certain atom/ion may not hold good which is actually the whole idea behind calling them "bands". The spread in energy (causing bandwidth) will be another obvious answer.
Thread Closed
Similar Threads for: How do free electrons impact reflectivity
Thread Forum Replies
Ball in Free Fall, Average Force Created on Impact (Bounce Up) Introductory Physics Homework 1
Free electrons General Physics 2
Gravitational Potential Energy during a Free-Fall Impact Classical Physics 5
Speed of Impact of electrons in a television. Introductory Physics Homework 2
