Register to reply
Finding Bearing and Distance using Calculator?
by ScieneBoy
Tags: bearing, calculator, distance
Share this thread:
ScieneBoy
#1
Mar22-10, 05:03 PM
P: 9
∆Eastings + 262.575
∆Northings + 929.573
Bearing = not an idea how to work it out
Distance = Pol(∆Northing,∆Easting)= displays distance
Please help, thanks!
Phys.Org News Partner Science news on Phys.org
Experts defend operational earthquake forecasting, counter critiques
EU urged to convert TV frequencies to mobile broadband
Sierra Nevada freshwater runoff could drop 26 percent by 2100
willem2
#2
Mar22-10, 05:34 PM
P: 1,398
Quote Quote by ScieneBoy View Post
∆Eastings + 262.575
I have no Idea how your calculator might work. Apparently the Pol() function converts an x and and y distance in polar coordinates. A second number should be produced that gives the bearing.
mgb_phys
#3
Mar22-10, 05:40 PM
Sci Advisor
HW Helper
P: 8,953
Have you heard of tan()?
Take a look at arctan or better atan2
ScieneBoy
#4
Mar22-10, 05:45 PM
P: 9
I'm completely new to my professional practice course and we have been given a presentation to do from scratch so I'm learning from the very bottom despite it being University work, I have never done this before.
tan-1 (1662.275)/893.463 = 0.1001
How does this convert into a bearing, presuming this is the right method to use.
mgb_phys
#5
Mar22-10, 05:54 PM
Sci Advisor
HW Helper
P: 8,953
ok - don't worry surveying is all just junior school maths really.
Firstly get used to drawing some diagrams - and get some graph paper.
Then a couple of gotcha's:
Surveying uses Northing and Easting rather than X and y. Northing is up the page = Y and Easting is to the right = X.
Angles are measured clockwise from north.
So to get the bearing you just draw an N(up) and E(to the right) axis.
The point is at 262 units across and 929 units up.
Draw a line back to the origin.
You are looking for the angle this line makes with the north axis (ie up the page)
Remember
sin = opposite/hypotenuse
cos = adjacent/hypotenuse
tan = opposite/adjacent
You know the distance opposite the angle (it's the same as the distance along the East axis) and the distance adjacent to the angle (it's the distance up the North axis)
So tan(bearing) = easting / northing
or atan(easting / northing) = bearing
The length of the line you can get from the same trig or from pythagorus
Apart from having to deal with deg/min/sec that's about all there is to it - except for holding a survey pole steady and not dropping the theodolite.
ScieneBoy
#6
Mar22-10, 06:11 PM
P: 9
Sadly I need to know deg/min/sec too, if that is something like 317 40’ 44”
mgb_phys
#7
Mar22-10, 06:21 PM
Sci Advisor
HW Helper
P: 8,953
Simple enough
there are 60mins in a degree and 60secs in a minute
So to convert dms to deg
deg = deg + min/60 + sec/(60*60)
To convert deg back to dms.
deg = just take the whole number.
Then multiply the decimal part by 60 = the minutes are the whole number
Then multiply the decimal of that by 60 = the seconds are the result
eg 1deg 10min 20sec
= 1 + 10/60 + 20/3600 = 1.1722
1.1722 = take whole part = 1 deg
0.1722 * 60 = 10.333, take whole part = 10 mins
0.333 * 60 = 20.0 = the seconds
there is probably a button on your calculator to do this for you
ScieneBoy
#8
Mar22-10, 06:24 PM
P: 9
I seriously can't thank you enough. You've certainly bumped my grade up with that, so thank you very much.
So if you had
26 12’ 48”
172 23’ 08”
How would you work out horizontal angle? I already know the answer is 146 10’ 20” just not sure how to get to it.
Last question, promise as I'm nagging now :)
ScieneBoy
#9
Mar22-10, 06:38 PM
P: 9
So if you had
26 12’ 48”
172 23’ 08”
mgb_phys
#10
Mar22-10, 06:44 PM
Sci Advisor
HW Helper
P: 8,953
26 12’ 48” --> 172 23’ 08”
end - start = 172 23’ 08” - 26 12’ 48” = 172.3855 - 26.2133 = 146.1722 = 146 10' 20"
ScieneBoy
#11
Mar23-10, 06:35 AM
P: 9
Anyone know how to display the bearing (deg/min/sec) with the Northing and Easting?
weltwireless
#12
Oct9-10, 10:33 PM
P: 1
Javascript geodetic azimuth distance/bearing Calculator:
http://mysite.verizon.net/weltwirele...ce_bearing.htm
mysite.verizon.net/weltwireless/tech/distance_bearing.htm
This calculator is based on "Vincenty's Formula" for elliptical Earth. It is not based on the "Great circle formula" which is innacurate and assumes a "round" Earth.
Comprises two programs essentially the same as INVERSE & FORWARD available at National Geodetic Survey.
INVERSE - computes the geodetic azimuth (bearing) and distance between two points, given their geographic positions. FORWARD - computes the geographic position of a point, given the geodetic azimuth (bearing) and distance from a point with known geographic position.
Calculate the geodetic azimuth and distance between two points (Inverse)
Enter lat/long. of two points, select distance units and Earth model and click "compute".
Note that if either point is very close to a pole, the course may be inaccurate, because of its extreme sensitivity to position and inevitable rounding error.
Register to reply
Related Discussions
Finding the angle without a calculator (CA) Precalculus Mathematics Homework 2
Finding Distance Introductory Physics Homework 31
Earth-sun distance calculator General Physics 0
Earth-sun distance calculator General Physics 1
Finding roots without a calculator? General Math 19
