Does Mass disappear and become Energy?
  • Context: Undergrad
  • Thread starter Thread starter Phrak
    Energy Mass
The discussion revolves around the relationship between mass and energy, particularly in the context of the equation E=mc² and its implications. Participants explore whether mass can be converted into energy and vice versa, examining different interpretations and applications of these concepts within the framework of special relativity and particle physics.
  • Some participants propose that E=mc² indicates mass and energy are equivalent, while others suggest that E + mc² = constant implies a conservation principle where one form can be transformed into the other.
  • There is a suggestion that the two equations are not necessarily competing but rather compatible, as raised by one participant.
  • Concerns are expressed about the specific definitions of energy and mass being used, particularly distinguishing between rest mass and kinetic energy.
  • Examples are requested to illustrate the application of the conservation of mass-energy in particle collisions, where mass can be created from kinetic energy.
  • Some participants assert that total mass-energy is conserved during particle interactions, while others emphasize the distinction between exchanged and conserved quantities.
  • There is a discussion on the invariant nature of mass in modern physics, contrasting it with the concept of relativistic mass and its implications for energy transformations.
  • One participant mentions the analogy between mass and proper time, suggesting a conceptual framework for understanding non-conservation of mass.
Participants express differing views on the compatibility of the equations and the implications of mass-energy conversion. There is no consensus on whether mass can be considered to disappear or transform into energy, and the discussion remains unresolved with multiple competing interpretations.
Participants highlight the importance of context in discussing mass and energy, noting that definitions may vary based on the framework (e.g., special relativity vs. Newtonian mechanics) and the specific forms of energy and mass being referenced.
Phrak
Every so often hear things similar to:
The mass lost is due to the energy produced. Mass becomes energy from the equation E=mc2.​
We seem to have two competing ideas:
1) E=mc2
2) E + mc2 = constant.
A) In equation 1) energy and mass are equivalent (up to a units conversion factor).
B) In equation 2) the sum is conserved--one is changed into the other.
Any disagreement?
What makes you think these ideas are 'competing'?
They seem perfectly compatible to me.
I dunno. What happens if you accept both equations and solve for E?
Can you give a specific example where this idea is used? I suspect that the E in this case is kinetic energy and the m is invariant mass ("rest mass").
In general, you have to be careful about which energy and which mass you're talking about. Also whether you're talking about a single particle or a collection of particles.
The most general equation is E=constant, where E includes rest mass energy, potential energy, and every other form of energy you care to dream of.
You get E = constant/2. What's the problem?
This is of course assuming that the equations are correct, or even make sense, which itself shows a certain misunderstanding happening.
I use the mass, m the same in each case, as inertial mass.
I think I could ask around and get any number of specific examples where it it a commonly accepted belief that energy is converted to mass. Maybe I should take a poll...
The Wikipedia authors of Mass-Energy Equivalence thought it something that required repeating in several different ways.
"Rather, neither one appears without the other. Rather than mass being changed into energy, the view of relativity is that rest mass has been changed to a more mobile form of mass, but remains mass. In this process, neither the amount of mass nor the amount of energy changes."
Have you noticed this opinion at all yourself?
I assume that you're talking about special relativity ( otherwise, mass is conserved in Newtonian mechanics).
The Newtonian concepts of mass & energy lose their individual meaning in Special Relativity. One has a compatible 4-vector (the energy-momentum vector) which looks like (0,0,0,mc^2) in the stationary frame of reference.Its (covariant)magnitude is defined as the energy.
Here's one from USA Today
http://www.usatoday.com/tech/columnist/aprilholladay/2006-10-30-mass-energy-eyes_x.htm"
Q: It is possible to convert mass into energy, but can we do the reverse? (Hardeepsingh, Derabassi, Punjab, India)
A: Yes, we routinely make mass from kinetic (moving) energy generated when particles collide at the near-light speeds attained in particle accelerators. Some of the energy changes into mass in the form of subatomic particles, such as electrons and positrons, muons and anti-muons or protons and anti-protons. The particles always occur in matter and anti-matter pairs, which can present a problem because matter and anti-matter mutually destruct, and convert back to energy."
Einstein showed us, with his deceptively simple equation (energy = mass times the speed of light, squared), that mass is simply another form of energy. We can, and do, go both ways: mass to energy and energy to mass. But we don't make much mass.
My boldface.
Physic Forum, 2008 https://www.physicsforums.com/showthread.php?t=254886"
hmm.. indeed energy can be converted in mass and vice versa ! x-ray can be broken into electron-positron pair! this is largely seen in the bubble chamber.
positron is the positive counterpart of electron. also annihilation of this pair gives out energy in the form of radiation! annihilation and nuclear fusion are the other examples of conversion of mass into energy.
No one seems to have noticed.
I focused on .edu websites:
...is inconsistent is to say that mass and energy are the same property of physical systems but that the conversion of mass into energy (or vice versa) is a genuine physical process.
--Standford website
Each lift has a mechanism which can transform its own mass into energy for...
--Harvard website
perfectly efficient mechanism for converting rest mass into energy
--Cornell website
...nuclear mass into energy.
--Stanford SLAC :eek:
...star formation in converting mass into energy,...
--Yale Astronomy website
And my favorite Princeton
...there is no problematic conversion of mass into energy or enigmatic creation...
I didn't make it up!
Look, I am sane, I am sane like the rest of you! --Catch 22, the movie, via Joseph Heller, author
I'm not seeing the issue. When composite 'particles' break up or are formed, rest mass can be exchanged for kinetic energy (and vice versa) or other forms of energy (radiation). The total 'mass-energy' is conserved, of course.
Scroll to the top of the screen. You are posting in a Special and General relativity folder.
That is not the energy momentum 4-vector. In any case, not this mass: m=|-p,E|, but this mass: E=m is the topic that evades discussion.
Do you see the difference between exchanged and conserved?
We write this for exchanged.
[tex]E \Leftrightarrow mc^2[/tex]
which is the same as E + mc2 = const
We write this for conserved
E1=E2.
E varies in the first. E changes form but is invariant in the second.
Phrak said:
Do you see the difference between exchange and conserved?
Sure. Do you see the difference between rest/invariant mass and the old-fashioned 'relativistic' mass? (Perhaps that's what's messing things up.)
Rest mass is not conserved. But total energy (including the rest energy, E = mc²) is conserved.
According to the modern definition, the mass of a particle is an invariant quantity, and it doesn't depend on which coordinate system it is described from. Energy, kinetic energy and momentum are not invariant quantities, and they depend on the coordinate system.
If a particle of mass m disintegrates into two particles that move away with velocity v, then the sum of the masses of the resulting particles is m√(1 - v2) (< m). Here mass is converted into kinetic energy.
If two particles of mass m collide and stick together with a relative velocity 2v, then the mass of the resulting particle will be 2m/√(1 - v2) (> 2m), so here kinetic energy is converted into mass.
I don't care to trade insults, if this is where this is going.
Also, it may be useful to note that mass is in a sense analogous to proper time. In this analogy, the non-conservation of mass is equivalent to the "twin paradox".
Hi Phrak,
First, when you use the equation E=mc² it is important to know which E and which m you are talking about. Usually E in this context refers to the rest energy and m refers to the rest mass.
By the conservation of four-momentum one particle of mass m may be exchanged for two or more photons of total energy E and each photon individually of rest mass 0. That is all that is meant by the equivalence of mass and energy.
Note that although the sum of the masses of the photons is zero the system of photons has mass m, which is a subtelty that is usually overlooked.
When people talk about "converting mass into energy" or vice versa, they are really talking about converting rest energy into kinetic energy and vice versa. For example, consider nucleus A which fissions into nuclei B and C.
If A is at rest initially, all its energy is rest energy which is associated with its rest mass:
[tex]E_A = E_{A0} = m_{A0} c^2[/tex]
whereas B and C each have both rest energy and kinetic energy:
[tex]E_B = E_{B0} + K_B = m_{B0} c^2 + K_B[/tex]
[tex]E_C = E_{C0} + K_C = m_{C0} c^2 + K_C[/tex]
The total energy is conserved:
[tex]E_A = E_B + E_C[/tex]
[tex]E_{A0} = E_{B0} + K_B + E_{C0} + K_C[/tex]
[tex]m_{A0} c^2 = m_{B0} c^2 + K_B + m_{C0} c^2 + K_C[/tex]
I consider it incorrect (strictly speaking) to say that some of A's mass was "converted" into energy because that implies (to me) that the energy didn't exist before and that the total energy increases. But in fact, the energy did exist before, as (part of) A's rest energy; and the total energy remains constant, so no new energy was created.
If you prefer to think in terms of "relativistic mass," then
[tex]E_A = m_{A,rel} c^2[/tex]
and similarly for B and C; and
[tex]m_{A,rel} c^2 = m_{B,rel} c^2 + m_{C,rel} c^2[/tex]
In this case the total "relativistic mass" is constant. Again it's incorrect to speak of some of it being "converted" into energy because that implies (to me) that the total "relativistic mass" should decrease.
Nevertheless, the colloquialism "converting between mass and energy" is so common that it's certainly impossible to eradicate. I think the best we can do is to interpret it as "converting between rest energy and kinetic energy."
Thanks Dale and jtbell for your thoughtful responses. I seem to simply have no more to add.
I think you've switched over to intrinsic mass in this statement, right? In any case, I hadn't really gotten that far with it. I think this is something ZapperZ would call a one body solution to an n-body problem, or n one-body solutions to an n-body problem.
You are very welcome. And sorry about the lack of clarity in that post. I was referring specifically to the invariant mass when I said "although the sum of the masses of the photons is zero the system of photons has mass m".
Say one photon has a four-momentum (E/c,E/c,0,0) and another photon has a four-momentum (E/c,-E/c,0,0), then each one individually has a mass of 0. Now if we take the two four-momenta and add them together we get (2E/c,0,0,0) for the four-momentum of the system, which has a mass of 2E/c². Does that help explain it better that time?
Yes, I'd thought that was what you were saying. I've been comfortable in assuming that the vector addition of (1/2)(E/c,E/c,0,0) and (1/2)(E/c,-E/c,0,0) should be plausible due to the indeterminate trajectory of a single particle, such as a photon in a laser cavity oriented along the x axis; and by extension groups of identical particles. (the mass would be the magnitude of the vector)
Until you'd put it into words, the notion that sum of the masses was not necessarily equal to the whole hadn't managed to breach my preconcieved expectations. That helps a great deal! I'm curious. How did you manage it?
  • · Replies 16 ·
  • · Replies 18 ·
  • · Replies 131 ·
13K
  • · Replies 48 ·
9K
