What is the ratio test and how does it apply to Baby Rudin, Example 3.35?
  • Thread starter Thread starter union68
    Example
The discussion centers on the application of the ratio test to the series \(\frac{1}{2} + \frac{1}{3} + \frac{1}{2^2} + \frac{1}{3^2} + \frac{1}{2^3} + \frac{1}{3^3} + \ldots\). The calculations show that \(\lim \textnormal{inf}_{n\to\infty} \frac{a_{n+1}}{a_n} = 0\) and \(\lim\textnormal{sup}_{n\to\infty}\frac{a_{n+1}}{a_n} = +\infty\), indicating that the limits are unequal. This leads to the conclusion that the limit \(\lim_{n \rightarrow \infty} \frac{a_{n+1}}{a_n}\) does not exist due to the alternating behavior of the subsequences derived from the series.
  • Understanding of the ratio test in calculus
  • Familiarity with limits, specifically lim inf and lim sup
  • Basic knowledge of series convergence
  • Ability to manipulate sequences and series
  • Study the detailed mechanics of the ratio test in calculus
  • Learn about subsequences and their impact on limits
  • Explore examples of series that exhibit similar behaviors
  • Investigate the concept of convergence and divergence in series
Students of calculus, mathematicians analyzing series convergence, and educators teaching the ratio test and its applications in real analysis.
union68
Consider the series
[tex]\frac{1}{2} + \frac{1}{3} + \frac{1}{2^2} + \frac{1}{3^2} + \frac{1}{2^3} + \frac{1}{3^3} + \ldots[/tex].
He then proceeds to write
[tex]\lim \textnormal{inf}_{n\to\infty} \frac{a_{n+1}}{a_n} = \lim_{n\to\infty} \left(\frac{2}{3}\right)^n = 0[/tex]
and
[tex]\lim\textnormal{sup}_{n\to\infty}\frac{a_{n+1}}{a_n} = \lim_{n\to\infty} \frac{1}{2} \left(\frac{3}{2}\right)^n = +\infty[/tex].
This is in reference to the ratio test, by the way.
How did he arrive at these calculations? If for the lower limit we select [itex]a_{n+1} = 1/3^n[/itex] and [itex]a_n = 1/2^n[/itex], then we can recover his answer. But
[tex]\left\{\frac{a_{n+1}}{a_n}\right\} = \left\{\left(\frac{2}{3}\right)^n\right\}[/tex]
is a convergent sequence and the upper and lower limits must be equal, correct? How is the upper limit [itex]\infty[/itex]?
On the other hand, if we select [itex]a_{n+1} = 1/2^{n+1}[/itex] and [itex]a_n = 1/3^n[/itex], then we can recover his answer for the upper limit.
Isn't there some ambiguity with selecting [itex]a_{n+1}[/itex] and [itex]a_n[/itex] from this series?
[tex]\frac{a_{n+1}}{a_n} = \left(\frac{2}{3}\right)^n[/tex]
is true for odd [itex]n[/itex] only.
[tex]\frac{a_{n+1}}{a_n} = \frac{1}{2} \left(\frac{3}{2}\right)^n[/tex]
is true for even [itex]n[/itex] only.
(or it might be the other way around, depending on how you index the terms)
Thus
[tex]\frac{a_{n+1}}{a_n}[/tex]
ping-pongs back and forth between the larger subsequence and the smaller subsequence. The larger one produces the lim sup and the smaller one produces the lim inf. Since the lim sup and the lim inf are unequal, it follows that
[tex]\lim_{n \rightarrow \infty} \frac{a_{n+1}}{a_n}[/tex]
does not exist.
Ah crap, got it! I should have wrote the sequence out so I could keep my indexing strait.
Thanks very much.
