Red and Blue shift
by Bjarne
Tags: blue, shift
Bjarne
Bjarne is offline
#1
Mar25-10, 02:32 PM
P: 344
How accurate is it possible to measure the EM spectre ?
Phys.Org News Partner Science news on Phys.org
Simplicity is key to co-operative robots
Chemical vapor deposition used to grow atomic layer materials on top of each other
Earliest ancestor of land herbivores discovered
FrankPlanck
FrankPlanck is offline
#2
Apr3-10, 03:07 AM
P: 31
It depends on your tool...
Bjarne
Bjarne is offline
#3
Apr3-10, 03:47 AM
P: 344
Quote Quote by FrankPlanck View Post
When the best possible is used
russ_watters
russ_watters is online now
#4
Apr3-10, 08:29 AM
Mentor
P: 21,998
Red and Blue shift
You're asking about the red and blue shift of stars and galaxies? Very accurately, since you have spectral absorption lines to compare with a reference.
Bjarne
Bjarne is offline
#5
Apr3-10, 08:33 AM
P: 344
Quote Quote by russ_watters View Post
Yes - Red and blue shift of stars and galaxies.
What is "very accurate" ?
1 millionth of a meter?
Which devise is the best ?
russ_watters
#6
Apr4-10, 01:07 PM
Mentor
P: 21,998
I've done some googling and haven't found too much, but this paper implies an accuracy of 0.1% to 1%.
http://www8.nationalacademies.org/as...ay.aspx?id=208
Redshift is measured with a spectrograph: http://en.wikipedia.org/wiki/Faint_Object_Spectrograph
Redshift doesn't directly measure speed or distance, it directly measures the shift in a spectrum of light.
Bjarne
Bjarne is offline
#7
Jul12-12, 01:29 AM
P: 344
What about absorbed photons, is it only these that has very certain frequencies that are absorbed?
For example here http://www.astro.ucla.edu/~wright/doppler.htm is mentioned that those at 393 nm are absorbed.
My question is; - how accurate is that?
Is it only these that have the exact wavelength 393nm that are absorbed
What when one is 394 nm or 392nm , - will noting happen ?
If so it must be possible to measure much more accurate as 0.1% to 1%.
I mean the difference between 393nm and 392 nm is not much.
mikeph
mikeph is online now
#8
Jul12-12, 05:48 AM
P: 1,197
The spectrograph gives you signal over a range of wavelengths, so you should see characteristic peaks on a graph.
393 nm/392 nm = 0.26% which seems nicely in the range 0.1-1%.
Janus
Janus is offline
#9
Jul12-12, 09:34 AM
Emeritus
Sci Advisor
PF Gold
Janus's Avatar
P: 2,352
Quote Quote by Bjarne View Post
There are a number of factors that determine the frequency range over which you will measure a spectral line:
http://www-star.st-and.ac.uk/~kw25/t...linewidths.pdf
Drakkith
Drakkith is offline
#10
Jul12-12, 06:43 PM
PF Gold
Drakkith's Avatar
P: 11,005
Those spectrographs are looking at light that was emitted from an object. The spectral lines are absorbed at the SOURCE, not the instrument. In other words, the line at 393 nm absorbed by calcium is a result of actual calcium in the star or galaxy absorbing the light, not calcium here on Earth. The light that is at 392 nm is NOT being absorbed by calcium, the line is wider than 1 nm because of several different effects, such as the rotation of the star. (Part of the star is moving away and part is moving towards us, so the line is wider than it would be otherwise) When we look at the patterns of lines in the spectrum and compare it with our own lines here on Earth we see a difference where the lines are shifted to the red end, aka redshifted. Measuring the difference between the lines we observe from the object and our comparison here in the lab we can tell how fast something is moving away from or towards us.
Dotini
Dotini is offline
#11
Jul13-12, 08:40 AM
PF Gold
P: 487
Quote Quote by Drakkith View Post
...spectrographs are looking at light that was emitted from an object. The spectral lines are absorbed at the SOURCE, not the instrument.
As a minor curiosity, an isolated lab test has apparently demonstrated that electron density (of intervening media?) may play some role in the story of spectral line shift phenomena.
http://www.sciencedirect.com/science...30402608000089
Respectfully submitted,
Steve
mfb
mfb is offline
#12
Jul13-12, 10:52 AM
Mentor
P: 10,767
This would imply a velocity of ~1/400c or about 1000km/s, which is equivalent to a rotational period of about an hour for a sun-sized star. As comparison: The sun's surface needs 25-30 days for a rotation (depends on the latitude), and 1/400c is much more than the escape velocity of stars.
There is no theoretic limit on the precision, and the technical limits depend on the instruments, measurement time and brightness of the source. Exoplanet searches can measure the radial velocity of nearby stars with a precision of ~1m/s which is equivalent to a relative precision of ~3*10^(-9). The key point here: While the actual lines are broader than this, the center of those lines can be measured with a precision better than the line widths.
Register to reply
Related Discussions
Red shift / Blue shift General Physics 1
Red shift, blue shift, or stupidity? Special & General Relativity 6
blue shift and red shift General Astronomy 2
Doppler shift and red/blue shift General Astronomy 4
Blue, Red shift General Physics 1
