Thread Closed
Hydrogen Sulfide and Hydrosulfuric Acid
Share Thread Thread Tools
Mar28-10, 12:23 AM   #1
In our chemistry class, we learned that an acid is a molecular compound that release hydrogen ions when they are dissolved in water through a process called ionization. So are both Hydrogen Sulfide (g) and Hydrosulfuric Acid (aq) acids?
PhysOrg.com
PhysOrg
chemistry news on PhysOrg.com
>> Explainer: What are chemical weapons?
>> Scientists develop advanced biological computer
>> Biofilms move electrons long distances across two distinct layers, even under starving conditions
Mar28-10, 04:43 AM   #2
Admin
If you ask me - that's a nitpicky question that doesn't have a definitive answer.
Definition is not clear, as it doesn't specify how to treat potential acid - substance that WILL release H+ WHEN put in water, but it is not yet in water. You can argue that it is an acid (it will when) and that it is not an acid (it is not in water and it is not releasing H+). So it is semantics.
Could be my English fails me. Second opinion won't hurt.
buffer calculator, concentration calculator
pH calculator, stoichiometry calculator
Mar28-10, 07:26 PM   #3
Recognitions:
Gold Membership Gold Member
They are the same substance...
It's just that H2S is called Hydrosulfuric Acid when aqueous solution, and Hydrogen Sulfide otherwise.
Mar28-10, 08:06 PM   #4
Its the same concept as Hydrogen Chloride gas. It could be an acid if it was aqueous.
Apr11-10, 07:35 AM   #5
my friend please confirm from teacher that if H2S reacts with a base it forms a salt and water or not
Apr11-10, 07:41 AM   #6
Admin
Yes, it does.
Apr11-10, 01:35 PM   #7
Recognitions:
Specifically, for a base Ca(OH)n, where Ca is any cation, the reaction proceeds as follows:
n H2S + 2 Ca(OH)n --> 2n H2O + Ca2Sn
I believe. So for NaOH it would be...
2 NaOH + H2S --> 2 H2O + Na2S
Apr11-10, 02:50 PM   #8
Admin
Ca is a poor idea for any cation symbol, Me is much better.
Formatting in your second equation went awry.
Apr11-10, 06:45 PM   #9
Me looks like methyl; M is generally used
Apr11-10, 11:08 PM   #10
Recognitions:
Fixed the format, and yeah, I should have done M.
Apr12-10, 02:39 AM   #11
Admin
Quote by Cesium View Post
Must be a matter of local convention, I am more than sure that I have books with Me in this room. But no doubts that you are right about possible confusion.
chemical calculators - buffer calculator, concentration calculator
www.titrations.info - all about titration methods
Thread Closed
Tags
acid, hydrogen, ion, ionization, sulfuric
Thread Tools
Similar Threads for: Hydrogen Sulfide and Hydrosulfuric Acid
Thread Forum Replies
Activating Zinc Sulfide for Glowing Chemistry 1
Reaction between Aluminum Sulfide and Bleach? Chemistry 6
VLE DATA FOR hydrogen sulfide N diethanolamine Chemistry 3
Neutralizing H2S-- Rendering Hydrogen Sulfide in the air into a non-toxic state Chemistry 6
HW HELP: decomposition of ferric sulfide Chemistry 1
