How can I use the power and quotient rule to solve this problem?
The discussion revolves around the differentiation of the function x/√(x² + 1) using both the quotient rule and the power rule. Participants are examining their results and attempting to reconcile discrepancies with the expected answer from a textbook.
  • Mathematical reasoning, Problem interpretation
  • The original poster attempts to differentiate the function using both the quotient and power rules but arrives at different expressions. Some participants analyze the results from the quotient rule and suggest ways to simplify or combine terms. Others ask for clarification on specific steps in the simplification process.
Participants are actively engaging with each other's findings, with some providing detailed breakdowns of the algebra involved. There is a focus on understanding the manipulation of fractions and common denominators, though no consensus has been reached on the correct approach or final answer.
There is an indication that the original poster is seeking guidance on the differentiation process, highlighting potential confusion around the application of rules and simplification techniques. The discussion does not provide complete solutions, maintaining a focus on exploration and clarification.
xvtsx
Hi everyone,
I have been trying to do this problem in both ways but I can't get the same answer the book says. This is the problem:
x/ sqrt (x^2 +1)
With quotient rule I got until the point I have [(x^2 +1)^1/2 - x^2/(x^2 +1)^1/2]/(x^2 +1)
And with power rule I have [1/sqrt(x^2 +1)] - [x^2/(x^2 +1)^3/2]
If you guys can walk me through the problem, it would be nice. Thanks :wink:
Well, let's look at your result from the quotient rule:
[tex]\frac{\sqrt{x^{2}+1}-\frac{x^{2}}{\sqrt{x^{2}+1}}}{x^{2}+1}=\frac{\sqrt{x^{2}+1}}{x^{2}+1}-\frac{x^{2}}{(x^{2}+1)\sqrt{x^{2}+1}}=\frac{1}{\sqrt{x^{2}+1}}-\frac{x^{2}}{(x^{2}+1)^{\frac{3}{2}}}[/tex]
Does that look familiar?
Furthermore, we may expand our first fraction with the factor (x^{2}+1).
Then, we get:
[tex]\frac{(x^{2}+1)-x^{2}}{(x^{2}+1)^{\frac{3}{2}}}=\frac{1}{(x^{2}+1)^{\frac{3}{2}}}[/tex]
Can you explain me in details how you combined that part of the fraction because I get lost here [tex]\frac{\sqrt {x^{2}+1}}{x^{2}+1}-\frac{x^{2}}{(x^{2}+1)\sqrt{x^{2}+1}}=\frac{1}{\sq rt{x^{2}+1}}-\frac{x^{2}}{(x^{2}+1)^{\frac{3}{2}}}[/tex].
You first multiply so all terms have a common divisor
[tex]\frac{\sqrt {x^{2}+1}*\sqrt{x^{2}+1}}{x^{2}+1}-\frac{x^{2}}{(x^{2}+1)\sqrt{x^{2}+1}}=\frac{1}{\sq rt{x^{2}+1}}-\frac{x^{2}}{(x^{2}+1)^{\frac{3}{2}}}[/tex]
and then simplify
as [tex]x^{2}+1[/tex] is the same as [tex](x^{2}+1)^{\frac{2}{2}[/tex] you multiply that with[tex](x^{2}+1)^{\frac{1}{2}[/tex]
Hope this helps
  • · Replies 25 ·
