What is the Torque Produced by a Beam and Sign on a Wall?
  • Thread starter Thread starter _wolfgang_
    Sign Wall
The problem involves calculating the torque produced by a uniform beam and a sign mounted on a wall. The beam has a specified mass and length, and the sign also has a defined mass. Participants are tasked with determining the total torque about the pivot point where the beam is attached to the wall.
  • Exploratory, Assumption checking
  • The original poster attempts to calculate the torque using the formula torque = F x perpendicular distance, considering the beam and sign separately. Some participants question the accuracy of the course book's answer and suggest it may contain errors.
The discussion is ongoing, with participants exploring potential discrepancies between the original poster's calculations and the course book's answer. Some guidance has been offered regarding the possibility of errors in the book, but no consensus has been reached regarding the correct answer.
There is mention of a potential error in the course book, with participants noting that the wording may differ from what they have. The original poster's calculations are based on the assumption that the beam and sign are treated as point masses at their respective centers of mass.
_wolfgang_
a uniform 2kg horizontal beam is 50cm long is bolted to a wall and supports a 5kg sign. calculate the tourqe produced by the combined weight of the beam and the sign about where it is mounted to the wall.
tourqe = F x Perpendicular distance
So I am using the wall as the pivot point making the distance to the centre of mass of the beam 0.25m.
the tourqe of the beam= (9.8x2)x(0.25)
= 4.9Nm
The tourqe of the sign= (9.8x5)x(0.5)
=24.5Nm
And to get the total tourqe i have added these togther to get 29.4Nm
But my course book says the answer is 118Nm?? i know this is a pretty simple question but i can't pick up my error :confused:
looks like a book error, if you described the problem correctly.
the only thing i changed from the book is that it says a light rather than a sign.. but i think it may be a book error to. This book has many errors
Well, one error is that it is a torque :biggrin:
you never know the book might spell it that way to?!??
  • · Replies 42 ·
11K
  • · Replies 28 ·
