Register to reply
How to find the minium coefficient of static friction?
by ARJewell
Tags: coefficient, friction, minium, static
Share this thread:
ARJewell
#1
Mar29-10, 10:03 AM
P: 6
For a system (with frictionless pulley) Mewsubk = .25 and the system is initially at rest. The mass of block 1 is 16 kg and the mass of block 2 is 12 kg. Determine the minimum coefficient of static friction needed to prevent any movement.
2. Relevant equations
F=ma
3. The attempt at a solution
I have no idea how to figure it out.
I figured out the acceleration to be 2.8m/s^2 because:
a= 12kg*9.8m/s^2 - .25*16kg*9.8m/s^2/(16kg+12kg)
I figured out the tension in the connecting string to be 84 N because:
T=mewsubk*m1g+m1a
Any help on how to figure out minimum coefficient of static friction?
Phys.Org News Partner Science news on Phys.org
Mysterious source of ozone-depleting chemical baffles NASA
Water leads to chemical that gunks up biofuels production
How lizards regenerate their tails: Researchers discover genetic 'recipe'
tiny-tim
#2
Mar29-10, 11:14 AM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,148
Hi ARJewell ! Welcome to PF!
(have a mu: and try using the X2 tag just above the Reply box )
Quote Quote by ARJewell View Post
F=ma
No, if movement is prevented (or even, in a different question, where the block is just moving), a must be zero!
Try again.
Register to reply
Related Discussions
How to find the maximum acceleration given coefficient of static friction and mass Introductory Physics Homework 6
Friction problem with banked curve given static friction coefficient Introductory Physics Homework 3
Find the coefficient of static friction...help? Engineering, Comp Sci, & Technology Homework 3
Confused - How do I find the static and kinetic friction coefficient? Introductory Physics Homework 2
Spinning carnival ride - need to find static friction coefficient, HELP! Introductory Physics Homework 8
