Is Z[x]/(2x) Isomorphic to Z/2Z?
  • Context: Graduate
  • Thread starter Thread starter jakelyon
    quotient Ring
The discussion revolves around the question of whether the quotient ring Z[X]/(2x) is isomorphic to Z/2Z. Participants explore the structure of the ideal (2x) and its implications for the elements of the quotient ring, as well as the necessary conditions to achieve an isomorphism with Z/2Z.
  • One participant suggests that every element in Z[x] can be expressed as a polynomial with integer coefficients, and questions whether the ideal (2x) corresponds to the set of multiples of 2x.
  • Another participant raises the issue of cardinality, prompting a comparison between Z/2Z and Z[x]/(2x).
  • A participant argues that modding out by (2x) effectively sends x to 0, leading to the conclusion that Z[x]/(2x) is equivalent to Z, not Z/2Z.
  • Another reply clarifies that while 2x = 0 in the quotient, x itself is not zero, and discusses the nature of the elements in Z[x]/(2x) as polynomials with certain coefficients.
  • It is noted that to obtain Z/2Z from a quotient of Z[x], one would need to quotient out by the ideal (2,x), which cannot be generated by a single element.
Participants express differing views on the structure of Z[x]/(2x) and its relationship to Z/2Z. There is no consensus on whether the two are isomorphic, and the discussion remains unresolved.
Participants highlight the distinction between integral domains and other types of rings, noting that Z[x] is not a principal ideal domain, which may affect the conclusions drawn about the ideals involved.
jakelyon
Can anyone explain, in detail, why/why not Z[X]/(2x) is isomorphic to Z/2Z? I know that every element in Z[x] can be written as a_0 + a_1 x + a_2 x^2 + ... with a_i in Z and only finitely many a_i's are nonzero. Now, does (2x) = (2, 2x, 2x^2,...)? Also, the quotient is "like" taking 2x=0, or x=0. Thus, I think that all elements of Z[x]/(2x) would look like a_0/2 for some a_0 in Z. But this does not give Z/2Z does it? Thanks.
What is the cardinality of Z/2Z? Then look at the size of Z[x]/(2x).
Thanks for replying daveyinaz, but I am not sure I am following. However, I been doing some reading:
(2x) is the ideal consisting of all linear combinations of 2x (with integer coefficients). Now, by moding Z[x] out by (2x) it is "like" sending x to 0. So, if I am correct, then Z[x]/(2x) = Z[0] =
Z, not Z/2Z, right?
Does this make sense? How would I get Z/2Z then? Thanks.
You are right that you can think of the quotient as forcing 2x = 0. However, this does not mean that x = 0, it means that all multiples of 2x by elements in Z[x] are equal to zero. So x is not zero since x is not a multiple of 2x in Z[x]. Also, all of Z will be in that quotient since no integer is a multiple of 2x in Z[x]. Things in Z[x]/(2x) will look like polynomials with any constant term but with coefficients on the other terms being 0 or 1.
Maybe part of your trouble is thinking that all rings are integral domains (integral domains are rings such that if ab = 0 then a = 0 or b = 0). This ring is not and there are more familiar ones that are not either such as the ring of all matrices.
If you want to get Z/2Z from a quotient of Z[x] you would have to quotient out by the ideal (2,x). Note that Z[x] is not a principal ideal domain and this ideal cannot be generated by a single element.
  • · Replies 0 ·
