Calculating Torque of a Solid Cylinder
  • Thread starter Thread starter Schu
    Torque
The discussion revolves around calculating the torque acting on an armature, which can be approximated as a solid cylinder. Participants are provided with specific parameters including radius, length, mass, and the time taken to accelerate to a certain speed.
  • Mixed
  • Participants explore the relationship between torque, force, and radius, with some referencing Newton's second law for rotational motion. There is uncertainty about the correct application of formulas and the role of rotational inertia and acceleration.
Several participants have offered guidance on how to approach the problem, suggesting different methods to calculate torque, including the use of rotational inertia and angular acceleration. There is ongoing clarification regarding the formulas involved and their application to the problem.
Participants express confusion over the correct formulas and their application, indicating a need for further clarification on the relationship between linear and rotational motion. There is also mention of the importance of unit conversion in the calculations.
Schu
I am attempting to the following question:
How large is the torque that act on an armature?
Particulars: (can be approximated as a solid cylinder)
radius of .081 m
length of .124 m
mass of 13.13 kg
Accelerated from REST to operating speed of 3530 rpm in 5.57 second
I know T = F*r
I'm not sure where to start.
You are given the mass, the radius, and a change in velocity over a given time interval.
Think of the problem another way:
T = F x r
from Newton's 2nd law: F = m*a
a = dv/dt
so you have: T = m dv/dt x r
start by converting the given velocity into meters per second, then calculating the acceleration. from there it is plug and chug
Newton's 2nd law - for rotational motion
Schu said:
I know T = F*r
You'll need to apply Newton's 2nd law for rotational motion:
[tex]\tau = I \alpha[/tex]
You are given all the information needed to calculate I (the rotational inertia) and [itex]\alpha[/itex] (the rotational acceleration).
Just to make sure you know that [itex]\tau = r \times F[/itex] not [itex]\tau = F \times r[/itex], it makes a difference. And [itex]||\tau||= rF\sin \phi[/itex]
Now ya'll have me confused again, I thought I was all set with the first formula,
T = f * r. Now where does Newtons Second Law fit into it to get the rotational movement.
Take me step by step if you would.
Thanks for the help so far
Good point, Corneo. (But it won't matter for this particular problem.)
T = r X F is true, but not helpful in this problem. Are you given the force? No.
This is just the rotational analog to an "F = ma" problem. Instead of m, you calculate I; instead of a, you calculate α. Then apply T = I α.
Give it a shot.
Ok check to see if I am OK on this;
we know T = I α
I = 1/2 mr^2 and α = a / r
so plug it in
I = (1/2) 13.13 * .081^2 = .043072965
α = (29.9425 / 5.57)/.081 = 66.36633641
Multiply the two together for T and you get 2.8585 Nm
How'd I do??
Looks good. Note that you can calculate [itex]\omega[/itex] directly from the rpm, then use it to calculate [itex]\alpha = \omega/t[/itex]. Just convert rpm to radians/sec.
  • · Replies 21 ·
  • · Replies 22 ·
