Why pressure is lower at the small bore of a venturi
  • Thread starter Thread starter thomas49th
    Pressure Venturi
In a venturi system, the pressure decreases at the smaller diameter due to the principles of fluid dynamics, specifically the conservation of energy as described by the Bernoulli equation. As the cross-sectional area decreases, the fluid velocity increases, resulting in a rise in kinetic energy (K.E.) and a corresponding drop in pressure energy. This relationship illustrates that pressure is a form of energy, as it requires work to move fluid through a system, quantified by the equation: pressure times volume equals work.
  • Understanding of Bernoulli's principle
  • Basic knowledge of fluid dynamics
  • Familiarity with kinetic and potential energy concepts
  • Ability to interpret pressure-energy relationships in fluid systems
  • Study the Bernoulli equation in detail
  • Explore the principles of fluid flow in constricted areas
  • Learn about pressure measurement techniques in fluid systems
  • Investigate applications of venturi effects in engineering
Engineers, physicists, and students studying fluid dynamics or related fields will benefit from this discussion, particularly those interested in the practical applications of pressure and energy in fluid systems.
thomas49th
Hi, why is it that in a venturi system the pressure is lower when the diameter of the cross sectional area is smaller?
I do not understand why pressure can be considered a form of "energy". I can understand that energy must be conserved and due to the reduction in the diameter the increase in speed (K.E increase) means a reduction in this pressure energy
Can someone please help me get my head around why this is the case?
Thanks
Thomas
Thanks
Thomas
It's considered energy because it requires work for the fluid to flow...i.e. pressure times volume equals work. You could also rewrite it as pressure time area = force, and force times distance = work. Since area times length (distance) is volume, pressure times volume equals work. Which means it requires energy in the form of pressure acting on a volume of fluid to get it to flow.
So if you look at the Bernoulli equation the first term would be the "pressure head" and is representative of this energy.
CS
  • · Replies 31 ·
54K
