Help with finding Moment of Inertia
In summary, the attempt at a solution for determining the moment of inertia of a cylinder of radius 0.37 m, height 1.8 m and density (1.11 − 0.555 r + 0.284 r2) kg/m3 about the center was incorrect and the student does not know what they are doing wrong.
yang09
76
Determine the moment of inertia of a cylinder
center.
Answer in units of kg · m2.
I=Integral[(r^2)dm]
I = mr^2
Density = Mass/Volume
Volume of a cylinder = (Pie)(radius^2)(Height)
I used the density formula and solved for mass, Mass = (Density)(Volume). To get the volume, I used the volume for a cylinder formula and plugged in my numbers. From the volume and density, I got mass = (1.11-0.555r+0.284r^2)(Pie)(.37^2)(1.8). I then plugged my mass into the Inertia equation, getting I = (mass)(.37^2). I calculated it all out and got I = 0.099997.
This is wrong and I don't know what I'm doing wrong. Am i supposed to integrate the radius, but that won't do anything because r is a constant.
The formula Mass = Density*Volume is applicable only when the density is constant. More generally, when the density depends on position
[tex]M=\int \rho(r) dV[/tex]
So to calculate the moment of inertia, first you need to replace dm with ρ(r)dV and then you need to do the (triple) integral
[tex]I=\int \rho(r) r^2 dV[/tex]
yang09 said:
I=Integral[(r^2)dm]
This is good. To set up the integral, treat 'dm' as the mass of a cylindrical shell. How would you express the volume and then the mass (dm) of that shell in terms of r and h?
Ok so by doing so, I got
I = (Pie)Integral[(1.11r^4)-(0.555r^5)+(0.284r^6)h].
But how would I integrate the function if there are two variables?
Looks off a bit to me. Please describe your volume element.
I only see one variable. (h is a constant.)
From Integral[(Density)(r^2)dV], I replaced dV with the cylinder volume, (Pie)(r^2)(height), and replaced density with (1.11-0.55r+0.284r^2).
After doing so, I got Integral[(1.11-0.55r+0.284r^2)(r^2)(Pie)(r^2)(h)]. I brought Pie in front of the integral because pie is a constant and multiplied the terms out. Ultimately getting Integral[(1.11r^4)-(0.555r^5)+(0.284r^6)h].
So what you're saying is to bring "h" out in front and treat it like pie?
No. dV is not the volume of the entire cylinder. (As kuruman pointed out, the density is not constant.) dV is volume of a thin cylindrical shell of radius r. Hint: Its thickness will be dr.
(And yes, you can treat h like any other constant.)
As you can tell, I'm new to this subject. Just please bear with me.
So I'm still confused. You're saying that dV is not the volume of the entire cylinder so I guess I'm not allowed to plug in the cylinder volume into dV. But if I'm not allowed to do that, then how I would I incorporate h into the integral?
dV will be the volume of a cylindrical shell of height h and radius r. So your integral will still have an h. Step one is to write dV in terms of r and h.
Tell me if this is correct, if I'm trying to find the change in volume, then that means that I am finding the area within the cylinder. And to do so, I would integrate the area of the cylinder, 2(pie)(radius)(height), making my dV become the area of the cylinder. Is this process right or is it not?
And then from here, I would distribute my terms out and integrate?
Let's tune that up a bit.
Looked at from above (along the axis of the cylinder) the shell is just a thin circular strip. Its radius is r, thus its length is 2πr. The thickness of the strip is dr, thus its area is 2πr dr. The volume of the corresponding shell is that area times the height, h. So dV = 2πr dr * h = 2πhr dr.
Make sense?
Ok thanks for all the help. It seems to make sense as of now. But I have to go to class in a couple of minutes so I can't really work out the problem now. But if I don't understand, then I'll just message again tomorrow. Thanks again
What is the moment of inertia?
The moment of inertia is a measure of an object's resistance to changes in its rotational motion. It is also known as the angular mass or rotational inertia.
How is the moment of inertia calculated?
The moment of inertia can be calculated by multiplying the mass of an object by the square of its distance from the axis of rotation. Alternatively, it can also be calculated using integrals in calculus for irregularly shaped objects.
What are some common units for moment of inertia?
The moment of inertia is typically measured in units of kilogram meters squared (kg m^2) in the SI system. In the Imperial system, it is measured in units of pound feet squared (lb ft^2).
Why is the moment of inertia important in physics?
The moment of inertia plays a crucial role in understanding the rotational motion of objects, such as spinning tops, wheels, and other rotating objects. It is also used in calculations for things like torque, angular acceleration, and rotational kinetic energy.
How does the moment of inertia differ from mass?
Mass is a measure of an object's resistance to linear motion, while the moment of inertia is a measure of an object's resistance to rotational motion. They are related but not equivalent concepts.
