| Thread Closed |
[SOLVED] Move that water! |
Share Thread | Thread Tools |
| Aug12-04, 02:31 AM | #1 |
Firstly g'day all, just had a glance through some of the topics and this seems like a fine forum.
Some of you may be able to help me with a little problem I've been juggling in my head for a couple of weeks. Say I had a 1000 litre tank of water say one metre above the ground. At the bottom of the tank I have an outlet coming out the side of the tank, for instance a 50 mill PVC pipe. Now, the problem I'm trying to overcome is, if I wanted to move as much of this water as possible to a higher location (higher than the outlet) into an inlet which is level with the top of the tank and about 2 metres away in horizontal distance, without using any additional energy except for the potential energy already in the tank and without the use of a syphon or pump or outside energy of any kind, how would I go about this? Looking at it, to me logically, any pipe I connect to the outlet and up, well, I would only be able to get the water through the pressure in the tank , to the level of the top of the water. But I need it to go into the inlet which faces the tank but only the bottom lip of the inlet in level with the top of the tank. I would usually be in the philosophical parts of this forum so am not quite the techincal man. Hopefully I've explained it clearly but if I haven't then say so and I'll try and whip up the scenario in paint or something. Cheers! |
| Aug12-04, 06:12 AM | #2 |
A picture would be good here! If you're trying to raise any water above the level that is at the surface of the water in the supply tank, you will need more than just a pipe. Perhaps a gravity pump would help? But yes, post a picture.
| Aug12-04, 06:32 AM | #3 |
Won't work.
The waterlevel in the tank it the same hight as the bottom of the target tank. It would only level out ti'll the level is equal in the source tank and the target tank. So in practice tou would probably only succede in getting a layer of about a cm in the target tank before the levels are in balance, that or nothing at all. |
| Aug12-04, 07:24 AM | #4 |
But you *could* try a gravity pump!
| Aug12-04, 11:08 AM | #5 |
Mentor
| Aug12-04, 12:11 PM | #6 |
If he could, then he could repeat this process whith a third tank, and so on... |
| Aug12-04, 01:34 PM | #7 |
Gravity Pump |
| Aug14-04, 01:58 PM | #8 |
Mentor
| Aug14-04, 05:51 PM | #9 |
And the truth is: using a siphon you can get water above the bottom of the first tank, of course, but you will never get any water above the level of the first tank. |
| Aug15-04, 10:59 AM | #10 |
Mentor
| Aug15-04, 07:21 PM | #11 |
As I told you before, the point is how to get USABLE water (OUTSIDE any siphons) in a second tank above the first one. And, once more, the truth is: using a siphon you can get water above the bottom of the first tank, of course, but you will NEVER get any water ABOVE THE LEVEL of the first tank. |
| Aug15-04, 10:40 PM | #12 |
Mentor
| Aug16-04, 04:21 AM | #13 |
Yes, but the container you're collecting it in can't be higher than your fuel tank!
| Aug16-04, 04:42 AM | #14 |
In other words nothing will work, at least nothing that doesn't use external power to move the water. Lik i said, the water will fill the pipe and stay there because the filling of the pipe will definately lower the waterlevel below the bottom of the second container. |
| Aug16-04, 07:37 AM | #15 |
| Aug16-04, 07:51 AM | #16 |
Ok but that would require you to dump the water used to move the pump.
(same principle is used to boost the pressure in air tanks when there isn't a compressor around with suffcient capacity). I did not take wasting water in my reasoning. But your right, with sacreficing water you could be able to get some water in the 2nd tank. |
| Aug16-04, 08:45 AM | #17 |
Take a careful look at THERE. Again, the truth is: using a siphon you can get water above the bottom of the first tank, but you will NEVER get any water ABOVE THE LEVEL of the first tank. I'm afraid you don't believe in this. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: [SOLVED] Move that water!
| [SOLVED] Water Refraction | Introductory Physics Homework | 1 | ||
| [SOLVED] Work Needed to Move a Charge | Introductory Physics Homework | 2 | ||
| [SOLVED] Two carts with masses of 8.0 kg and 1.8 kg, respectively, move on a friction | Introductory Physics Homework | 2 | ||
| [SOLVED] Removing Pb from water | Chemistry | 5 | ||
| [SOLVED] Water expansion | General Physics | 15 | ||
